I am using Bing maps as my world map overlay and need to go to a lower level of zoom than the default value. I have tried changing the scale value the ZoomLevelSet.ZoomLevel20, however this does not seem to do anything below a certain value. Once the zoom level is below the maximum zoom level for the Bing maps overlay, I would like it to just drop off or disappear. I have some graphics overlaid on the world map using GdiPlusRasterLayers and I would like to further zoom in on these graphics beyond whatever the default max zoom level is for Bing. How can accomplish this?
Thanks in advance for your help,
Dave
Lower zoom level with Bing maps
Hi David,
Following is the scripts on how to zoom Bing Maps further and the Bing maps tile will disappear beyond the maximum zoom levels.
Client Side:
function OnOverlaysDrawing(layers) {
for (var index = 0; index < layers.length; index++) {
var templayer = layers[index];
if (templayer.CLASS_NAME.contains(‘Bing’)) {
templayer.MIN_ZOOM_LEVEL = 0;
templayer.MAX_ZOOM_LEVEL = 22;
templayer.resolutions.push(templayer.resolutions[19] / 2);
templayer.resolutions.push(templayer.resolutions[20] / 2);
var OnMapCreating = function (map) {
OpenLayers.Tile.Image.prototype.renderTile = function () {
if (this.layer.CLASS_NAME.contains(‘Bing’) && this.layer.map.getZoom() > 20) {
return true;
if (this.layer.url == null || this.layer.url == ‘’) {
return true;
if (this.imgDiv == null) {
this.initImgDiv();
this.imgDiv.viewRequestID = this.layer.map.viewRequestID;
if (this.layer.url instanceof Array) {
this.imgDiv.urls = this.layer.url.slice();
this.url = this.layer.getURL(this.bounds);
if (this.url && !this.url.contains(‘blank.gif’) && !this.layer.CLASS_NAME.contains(‘OSM’)
&& !this.layer.CLASS_NAME.contains(‘WMTS’)) {
this.url += ‘&ZOOM=’ + this.layer.map.getZoom();
OpenLayers.Util.modifyDOMElement(this.frame,
null, this.position, this.size);
var imageSize = this.layer.getImageSize();
if (this.layerAlphaHack) {
OpenLayers.Util.modifyAlphaImageDiv(this.imgDiv,
null, null, imageSize, this.url);
} else {
OpenLayers.Util.modifyDOMElement(this.imgDiv,
null, null, imageSize);
this.imgDiv.src = this.url;
return true;
Server Side:
protected void Page_Load(object sender, EventArgs e)
if (!Page.IsPostBack)
Map1.CurrentExtent = new RectangleShape(-13939426.6371, 6701997.4056, -7812401.86, 2626987.386962);
Map1.MapUnit = GeographyUnit.Meter;
BingMapsOverlay bingMapsOverlay = new BingMapsOverlay(“BingMaps Map”);
bingMapsOverlay.MapType = BingMapsStyle.Road;
Map1.CustomOverlays.Add(bingMapsOverlay);
Hi Johnny.
Thanks for the quick reply! The sample provided allows for 22 zoom levels and the bing tiles drop off as intended, which is great. However, when the bing tiles drop, so does my gdiRasterLayer. Below is my server side code (please pardon my VB, I converted your sample) to build this additional overlay & layer. I tried a few things with the client side script to get this to be rendered on the higher zoom levels, but didn’t have any luck. Could you help me figure out what is required to get the graphics overlay/layer (production will have multiple layers in the graphics overlay) to be displayed on the new zoom levels 21&22?
Thanks again for your help with this, you guys are awesome!
Map1.MapBackground.BackgroundBrush = New GeoSolidBrush(GeoColor.FromHtml("#E5E3DF"))
Map1.CurrentExtent = New RectangleShape(-13939426.6371, 6701997.4056, -7812401.86, 2626987.386962)
Dim bingMapsOverlay As New BingMapsOverlay(“BingMaps Map”)
'bingMapsOverlay.IsBaseOverlay = true;
Map1.MapTools.MouseCoordinate.Enabled = True
'set up graphics overlay
Dim imO As New LayerOverlay(“graphicsOverlay”)
imO.IsBaseOverlay = False
imO.Opacity = 0.75
imO.Name = “graphicsOverlay”
'RectangleShape mapExtent = new RectangleShape((-119.92033813128, 38.9788664699946, -119.920575860844, 38.9791001997615);
Dim mapExtent As New RectangleShape(“POLYGON((-119.920575860844 38.9791001997615,-119.920575860844 38.9788664699946,-119.92033813128 38.9788664699946,-119.92033813128 38.9791001997615,-119.920575860844 38.9791001997615))”)
'projection from lat/lon to meters
Dim myProjection As New Proj4Projection
myProjection.InternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(4326)
myProjection.ExternalProjectionParametersString = Proj4Projection.GetGoogleMapParametersString()
myProjection.Open()
mapExtent = myProjection.ConvertToExternalProjection(mapExtent)
myProjection.Close()
Dim imageID As String = “ec1de86e-b3b5-46ac-840d-8406ce805ec1”
Dim mapPath As String = “xxx.blob.core.windows.net/dev/ec1de86e-b3b5-46ac-840d-8406ce805ec1.png”
mapPath = CacheImageLocally(mapPath, imageID, “.png”)
Dim gdiLayer As New GdiPlusRasterLayer(mapPath, mapExtent)
gdiLayer.Name = imageID
imO.Layers.Add(imageID, gdiLayer)
'add imo to map
Map1.CustomOverlays.Add(imO)
Hi David,
The codes we provided before might not be fit for you, please try the new one which is using the custom zoomlevel set:
Server side:
Protected Sub Page_Load(sender As Object, e As EventArgs)If Not Page.IsPostBack ThenMap1.MapBackground.BackgroundBrush = New GeoSolidBrush(GeoColor.FromHtml("#E5E3DF"))Map1.CurrentExtent = New RectangleShape(-13939426.6371, 6701997.4056, -7812401.86, 2626987.386962)Map1.MapUnit = GeographyUnit.MeterDim customZoomlevelSet As ZoomLevelSet = GetCustomZoomlevelSet()Map1.ZoomLevelSet = customZoomlevelSet
Dim shapeFileFeatureLayer As New ShapeFileFeatureLayer(MapPath("~/SampleData/USA/STATES.shp"))For Each item As var In customZoomlevelSet.GetZoomLevels()item.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.FromArgb(100, 212, 220, 184), GeoColor.FromArgb(255, 132, 132, 154), 1)shapeFileFeatureLayer.ZoomLevelSet.CustomZoomLevels.Add(item)Next
Dim proj4 As New Proj4Projection()proj4.InternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(4326)proj4.ExternalProjectionParametersString = Proj4Projection.GetGoogleMapParametersString()shapeFileFeatureLayer.FeatureSource.Projection = proj4
Dim shapeOverlay As New LayerOverlay(“Shape Overlay”, True, TileType.SingleTile)shapeOverlay.IsBaseOverlay = FalseshapeOverlay.Layers.Add(shapeFileFeatureLayer)shapeOverlay.TransitionEffect = TransitionEffect.None
Dim bingMapsOverlay As New BingMapsOverlay(“BingMaps Map”)bingMapsOverlay.MapType = BingMapsStyle.RoadMap1.CustomOverlays.Add(New GoogleOverlay())Map1.CustomOverlays.Add(shapeOverlay)End IfEnd Sub
Private Function GetCustomZoomlevelSet() As ZoomLevelSetDim zoomlevelSet As New ZoomLevelSet()
Dim bingZoomlevelset As ZoomLevelSet = New BingMapsZoomLevelSet()For Each item As var In bingZoomlevelset.GetZoomLevels()zoomlevelSet.CustomZoomLevels.Add(item)Next
Dim zoomlevel21 As New ZoomLevel(zoomlevelSet.CustomZoomLevels(zoomlevelSet.CustomZoomLevels.Count - 1).Scale / 2)zoomlevelSet.CustomZoomLevels.Add(zoomlevel21)Dim zoomlevel22 As New ZoomLevel(zoomlevelSet.CustomZoomLevels(zoomlevelSet.CustomZoomLevels.Count - 1).Scale / 2)zoomlevelSet.CustomZoomLevels.Add(zoomlevel22)Dim zoomlevel23 As New ZoomLevel(zoomlevelSet.CustomZoomLevels(zoomlevelSet.CustomZoomLevels.Count - 1).Scale / 2)zoomlevelSet.CustomZoomLevels.Add(zoomlevel23)Dim zoomlevel24 As New ZoomLevel(zoomlevelSet.CustomZoomLevels(zoomlevelSet.CustomZoomLevels.Count - 1).Scale / 2)zoomlevelSet.CustomZoomLevels.Add(zoomlevel24)Return zoomlevelSetEnd Function
Client side:
<scripttype=“text/javascript”>function OnOverlaysDrawing(layers){for (var index = 0; index <layers.length; index++){vartemplayer=layers[index];if (templayer.CLASS_NAME.contains(‘Bing’)){templayer.MIN_ZOOM_LEVEL=0;templayer.MAX_ZOOM_LEVEL=24;templayer.resolutions.push(templayer.resolutions[19] / 2);templayer.resolutions.push(templayer.resolutions[20] / 2);templayer.resolutions.push(templayer.resolutions[21] / 2);templayer.resolutions.push(templayer.resolutions[22] / 2);}}}
OnMapCreated=function(map) {map.numZoomLevels=24;}
In the codes, I am using the shapeFileFeatureLayer instead of your GdiPlusRasterLayer, but it doesn’t not a big case to replace it.
If the issue persists, please feel free to let us know.
Regard,
I´m working on a similar scenario with one diference. I want that bing layer remains visible after zoom 20.
Is this possible?
in bing maps site we can zoom closer to the image.
See next examples using the same swimming pool.
Max zoom where i can see bing layer, after this zoom i can´t see the bing layer.
Luís Diogo
HI Luis,
Does Johnny’s code works for you in floor 2?
Hi Don, yes it works.
see video in next link:
meocloud.pt/link/e681f67d-1ff3-4939-8553-f862e94b917c/bingZoom.avi/
Hi Luis,
The code as below should works for you.
Client side:
<script type=“text/javascript”>
if (templayer.CLASS_NAME.indexOf(‘Bing’) > 0) {
templayer.serverResolutions = [156543.03390625, 78271.516953125, 39135.7584765625,
19567.87923828125, 9783.939619140625,
4891.9698095703125, 2445.9849047851562,
1222.9924523925781, 611.4962261962891,
305.74811309814453, 152.87405654907226,
76.43702827453613, 38.218514137268066,
19.109257068634033, 9.554628534317017,
4.777314267158508, 2.388657133579254,
1.194328566789627, 0.5971642833948135];
templayer.numZoomLevels = 24;
</script>
Server side:
For Each item As ZoomLevel In customZoomlevelSet.GetZoomLevels()
Next
End If
End Sub
For Each item As ZoomLevel In bingZoomlevelset.GetZoomLevels()
Next
Return zoomlevelSet
End Function
This code based on Johnny’s code and it works for me, please let me know whether that works for you.
