Maintain dynamic layer from disappearing
How do i prevent dynamic layer from disappearing whenever you zoom/pan ?
It would be nice if it behaves the same way as the static layer. When you drag, the image is still visible.
Kwong,
 This could be a bit tricky as I think we draw the dynamic layers as one large image to increase the speed.  I will see what we can do and we may be able to add a toggle so if you don’t want the optimization and want the image to load as tiles then you could do that.  Let me setup a test and get back with you.
