Making Marker Icons Invisible but keeping the popup
I have just switched over from evaluating the Silverlight version of map suite and I have a few questions.
What I want to do is have a custome feature layer that respresents the physical location of a station and the associate symbology for alarm states.  I have that working.
Each station has a variety of measurements.  I want to create a marker layer for each measurement that has a popup for each measurement.  the user can then choose a measurement and receive different popups on the same station icons.  Hiding all the marker layers but one works.
The problem I am having is that I only want the icons from my custom feature layer.  I do not want the markerlayer icons to be visible.  However I do want the popups and HTML(text) to be visible for the Marker layer and change with each layer.  I have tried turning the marker to IsVisible = false but that turns the html and popups off as well.
Is there a way to do this.
Here is the code I am using for my MakerOverlay
  SimpleMarkerOverlay testMarkerOverlay = new SimpleMarkerOverlay();
                Marker test = new Marker(-118.19, 34.64);
                CustomPopup cp1 = new CustomPopup("p1", test.Position, "<img src='Pipelines.jpg' />", 300, 200, false, false, 2);
                cp1.IsVisible = false;
                test.Popup = cp1;
                testMarkerOverlay.Markers.Add(test);
                Map1.CustomOverlays.Add(mapoverlay);
                //Map1.CustomOverlays.Add(testMarkerOverlay);
                Map1.CustomOverlays.Add(ShapeFiles1);
Here is the code for by customer Feature Layer
//declare a new EyascofeatureLayer
EyascoFeatureLayer EFL = new EyascoFeatureLayer();
//Get Layer Style Style st = ((EyascoFeatureSource EFL.FeatureSource).GetAlarmStyle();
EFL.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(st);
EFL.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;  ShapeFiles1.Layers.Add(EFL);
namespace ThinkGeo2
public class EyascoFeatureCache : ThinkGeo.MapSuite.Core.FeatureCache
private RectangleShape rec01;
public EyascoFeatureCache()
Init();
public void Init()
PointShape ulpnt = new PointShape(-118.15, 34.8);
PointShape lrpnt = new PointShape(-117.6, 32.7);
rec01 = new RectangleShape(ulpnt, lrpnt);
//create first "station"
Collection<string> attr = new Collection<string>();
attr.Add("stnId:1");
attr.Add("alarm:Level1");
Feature F1 = new Feature(-118.19, 34.64, "1", attr);
//Create second "station"
attr.Clear();
attr.Add("stnId:5");
attr.Add("alarm:Level2");
Feature F2 = new Feature(-117.9, 34.2, "2", attr);
//Create Third "station"
attr.Clear();
attr.Add("stnId:7");
attr.Add("alarm:Level3");
Feature F3 = new Feature(-118.05, 33.9, "3", attr);
Collection<feature> featureColl = new Collection<feature>();
featureColl.Add(F1);
featureColl.Add(F2);
featureColl.Add(F3);
Add(rec01, featureColl);
public RectangleShape getBounds()
return this.rec01;
namespace ThinkGeo2
public class EyascoFeatureSource : ThinkGeo.MapSuite.Core.FeatureSource
protected FeatureSourceColumn stnId;
protected FeatureSourceColumn alarm;
protected Collection<featuresourcecolumn> fsColl;  protected ValueStyle alarmStyle;
protected ValueItem Level1;
protected ValueItem Level2;
protected ValueItem Level3;
public EyascoFeatureSource()
//add columns to features
stnId = new FeatureSourceColumn("stnId", "string", 20);
alarm = new FeatureSourceColumn("alarm", "string", 20);
fsColl = new Collection<featuresourcecolumn>();
fsColl.Add(stnId);
fsColl.Add(alarm);
//set the alarm style
Level1 = new ValueItem("Level1", PointStyles.CreateSimpleCircleStyle(GeoColor.SimpleColors.Green, 15, GeoColor.FromHtml("White"), 3));
Level2 = new ValueItem("Level2", PointStyles.CreateSimpleCircleStyle(GeoColor.SimpleColors.Yellow, 20, GeoColor.FromHtml("Black"), 1));
Level3 = new ValueItem("Level3", PointStyles.CreateSimpleCircleStyle(GeoColor.SimpleColors.Red, 25, GeoColor.FromHtml("Black"), 1));
Collection<valueitem> cv = new Collection<valueitem>();
cv.Add(Level1);
cv.Add(Level2);
cv.Add(Level3);
alarmStyle = new ValueStyle("alarm", cv);
GeoCache = new EyascoFeatureCache();
protected override Collection<feature> GetAllFeaturesCore(IEnumerable<string> returningColumnNames)
EyascoFeatureCache test = new EyascoFeatureCache();
return GeoCache.GetFeatures(test.getBounds());
protected override Collection<featuresourcecolumn> GetColumnsCore()
return fsColl;
public Style GetAlarmStyle()
return alarmStyle;
So Basically I need to know if it is possible to have a Marker Layer active for Popups and HTML but have the actual Icon either transparent of invisible.  I was hoping to use a stack of Marker layers to control the different measurements (popups) all at the same location represented by the feature layer.
Any help would be greatly appreciated and thanks in advanced for your response.
Leon
Leon,
 Thanks for your information about this post.
 If you don’t want the icons but the Popup and its html, why don’t you use the Popup object directly? And add these Popups into Map control. If you don’t know how to do that, please refer to the “AddAPopup” sample in our installed samples.
 In fact, SimpleMarkerOverlay is used for markers that can have ContextMenu and Popup, but if you just set the IsVisible property of Marker as false, and the result is that we won’t render the popup also.
 If you still have any questions about it please let me know.
 Khalil
Thank you for the quick response Khalil
I saw the CustomPopup but i didn't see the example without using a marker.. I will look again.
Also what would you attach a Popup object to? A Feature? would you add it to a layer directly? Guess I need to find that example. Thanks again
Hi, Leon
 As for the “AddAPopup” sample and it doesn’t use a marker object but add the CloudPopup into Map control.
 Map control has a Popups property which is used to load popups.
 Khalil
