Map_Click buffer shape feature
I am attempting to create a buffer around a feature(lineshape) from the Map_Click event. I have my feature and distance, but clearly do not get the buffer part. I do not get any warnings or errors telling me this will not work. I took what I thought would work from forum posts and WIKI Multi Ring Buffering, again, clearly, I am not getting it.
For Each myFeature As Feature In closestline
  PIRdist = Convert.ToInt32(myFeature.ColumnValues("PIR"))
  Dim lshape As BaseShape = myFeature.GetShape()
  lshape.Buffer(PIRdist, GeographyUnit.DecimalDegree, DistanceUnit.Feet)
  foundlines.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.FromArgb(150, 50, 250, 250))
  foundlines.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
  foundlines.EditTools.Add(New Feature(lshape))
  foundlines.EditTools.CommitTransaction()
  foundlines.Close()
Next myFeature
Dim activesegmentOverlay As New LayerOverlay()
activesegmentOverlay.Layers.Add(foundlines)
Map.Overlays.Add("ActivesegmentOverlay", activesegmentOverlay)
Map.Refresh()
Hi Craig,
 It looks you buffer your shape under DecimalDegree with distance unit feet, so it should be very small change that cause you cannot watch it.
 Could you please try to set a bigger distance unit or select meter as map unit and try again?
Thanks Don, I tried them all meter, kilo.. I think I have the solution, here is the modified code, found some help here
http://community.thinkgeo.com/t/allowduplicateinquadrant/4694
  PIRdist = Convert.ToDouble(myFeature.ColumnValues("PIR"))
  Dim lshape As AreaBaseShape = myFeature.GetShape().Buffer(PIRdist, 30, BufferCapType.Round, GeographyUnit.DecimalDegree, DistanceUnit.Feet)
  foundlines.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.FromArgb(250, 50, 250, 250))
  foundlines.Close()
Next myFeature
Hi Craig,
 I am glad to hear you find the solution and thanks for your share, that’s should be helpful for other guys who met same question.
I am getting some rather erratic results creating a buffer at a certain distance in feet. Or maybe my measure tool I use to check the accuracy of the buffer distance is not measuring properly. I am seeing 10 to 50 foot difference between the two.
To measure I use currentCoords.GetDistanceTo(LastPoint, GeographyUnit.DecimalDegree, DistanceUnit.Feet)
I do not think my AreaBaseShape is as reliable or precise as my measure utility. Any thoughts?
Hi Craig,
 Do you meant you want to get a standard result?
 The buffer result should based on really earth, so I think if you want to get a standard result, you should want to put it in some special projection or calculate that near the equator.
 If possible please let me know your more detail requirement here.
I am primarily within the state of Texas between 94 and 104 west lon. and 29 and 35 north lat.
What I am saying if I do this I should see a buffer of 150 feet around the shape, pretty straight forward.
myFeature.GetShape().Buffer(150, 30, BufferCapType.Round, GeographyUnit.DecimalDegree, DistanceUnit.Feet)
Then I use GetDistanceTo to check that distance and, I should be within a few feet of the distance I specify for the buffer.
currentCoords.GetDistanceTo(LastPoint, GeographyUnit.DecimalDegree, DistanceUnit.Feet).
One of or both are not working as expected from my perspective, because I do not get the correct measurement for the buffer I apply to the map.
I cannot explain it any better than that. Thanks
Hi Craig,
 Thanks for your detail description.
 I did a test today, it looks the distance is nearly the same.
 LineShape line = new LineShape();
            line.Vertices.Add(new Vertex(100, 30));
            line.Vertices.Add(new Vertex(101, 30));
            Feature lineFeature = new Feature(line);
            MultipolygonShape bufferShape = lineFeature.GetShape().Buffer(150, 30, BufferCapType.Round, GeographyUnit.DecimalDegree, DistanceUnit.Feet);
            PointShape point = new PointShape(101.00045860032223, 30.000122881585991); // I get this value from bufferShape
            double distance = point.GetDistanceTo(new PointShape(101, 30), GeographyUnit.DecimalDegree, DistanceUnit.Feet); // result is 151.66533745100807
 If you found they are not the same, could you please double check whether your test data lost accuracy?
