Map_click event
Greetings
I added a click event for the map to get lat and long and store them in text boxes the issue i’m facing is that when i click on the map and the lat and long are registered in the text boxes the map disappears and i don’t know why any ideas?
Thanks in advance.
Hi Saddam,
 As below is my test code, it looks I haven’t reproduced your problem.
 Could you please try it and let me know your code if it don’t works for you.
<%@ Page Language=“C#” AutoEventWireup=“true” CodeBehind=“DisplayASimpleMap.aspx.cs”
    Inherits=“CSSamples.Samples.DisplayASimpleMap” %>
<%@ Register Assembly=“WebEdition” Namespace=“ThinkGeo.MapSuite.WebEdition” TagPrefix=“cc1” %>
<!DOCTYPE html PUBLIC “-//W3C//DTD XHTML 1.0 Transitional//EN” “w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd”>
<html xmlns=“w3.org/1999/xhtml”>
<head runat=“server”>
    <link href="~/theme/default/samplepic/style.css" rel=“stylesheet” type=“text/css” />
    <title>Display a Simple Map</title>
    <script type=“text/javascript”>
        OnMapCreated = function (map) {
            map.events.register(“click”, this, function (e) {
                var currentlatlon = map.getLonLatFromPixel(new OpenLayers.Pixel(e.clientX, e.clientY));
                var location = document.getElementById(“location”);
                location.innerHTML = currentlatlon;
    </script>
</head>
<body>
    <form id=“form1” runat=“server”>
    <asp:ScriptManager ID=“ScriptManager1” runat=“server”>
    </asp:ScriptManager>
    <cc1:Map ID=“Map1” runat=“server” Width=“100%” Height=“100%”>
    </cc1:Map>
    <Description:DescriptionPanel ID=“DescPanel” runat=“server”>
        <label id=“location”></label>
    </Description:DescriptionPanel>
    </form>
</body>
</html>
