My default setting for my Map control was default. Somewhere along the line the setting was changed to WaitCursor and now I cannot change it back. The setting is bold(WaitCursor), where in previous releases the setting is Default but not bold.
OK, I had to change the UseWaitCursor property for the Map control and the Panel the Map control was in to false, then I could change my Default property for the Map control back to Default.
Hi Craig,
It looks you have solved that? Please let me know which version you found the default value is changed, I will let our developer review that.
