Map Coordinates to WGS84
   I am triying to get coordinates in WGS84 mode using javascript. Is there any API functions used by JavaScript for this?
 var tgMap = null;
var showScreenPosition = function(e) {
    var lonlat = this.getLonLatFromViewPortPx(e.xy);
    var result = '';
    result += 'screenX = ' + e.xy.x + ',';
    result += 'screenY = ' + e.xy.y + ',';
    result += 'lon = ' + lonlat.lon + ',';
    result += 'lat = ' + lonlat.lat;
    alert(result);
var OnMapCreated = function(map) {
    tgMap = map;
    tgMap.events.register('mouseover', tgMap, showScreenPosition);
this function gives me the result such this : 3192096.0102896634 5035699.2570279529
but I want it as :28.6750863442015 41.1581665281288
Ayhan
Hi, Ayhan
 If you want to project the lonlat on the client-side, you may need to refer to the OpenLayers.Projection object. You could use it like this:
             var projectedLonLat = lonlat.transform(new OpenLayers.Projection("EPSG:900913"), new OpenLayers.Projection("EPSG:4326"));
             alert(projectedLonLat);
 Khalil
