Map.DrawStaticLayers OutOfMemoryException?
I'm encoutering a OutOfMemory exception when calling Map.DrawStaticLayers(bmp, GeographyUnit.Meter) for specifics areas.
Actually, my program generates pictures for the cache system, the bitmaps objects are correctly disposed, and the program never exceeds 120 Mb in Memory, but a OutOfMemoryException is thrown. The exception comes always for the same part of the map.
Here is the call stack :
 bei ThinkGeo.MapSuite.Core.Layer.Draw(GeoCanvas canvas, Collection`1 labelsInAllLayers)
 bei ThinkGeo.MapSuite.Core.MapEngine.x2a77eb6032362d14(Layer xa1d467ddfe47b178, Object x65e9a9c6c5e41d97)
 bei ThinkGeo.MapSuite.Core.MapEngine.x68ddaa28fe467d0a(IEnumerable`1 xbc8a920bd17eefdf, Bitmap xe10299f210688dae, GeographyUnit x23bf990a35721448, Boolean xa872403da055b02a)
 bei ThinkGeo.MapSuite.Core.MapEngine.DrawStaticLayers(Bitmap gdiPlusBitmap, GeographyUnit mapUnit)
 bei GisCacheGenerationTool.Window1.GenerateTileSquare(Int32 level, Int32 number, Int32 x, Int32 y, Size packSquareSize, Size boundingBoxSize, Int32 scaleId) in C:\projects\Kuba50\Implementation\Components\Src\GisCacheGenerationTool\GisCacheGenerationTool\Window1.xaml.cs:Zeile 310.
Here are some watchs from the used envronnement :
Map.StaticLayers (all layers are open)
Count = 25
    [0]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [1]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [2]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [3]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [4]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [5]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [6]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [7]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [8]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [9]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [10]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [11]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [12]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [13]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [14]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [15]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [16]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [17]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [18]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [19]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [20]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [21]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [22]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [23]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
    [24]: {ThinkGeo.MapSuite.Core.GeoTiffRasterLayer}
Map.CurrentExtent
{829995.080935478,302615.353243947,859293.954696049,273316.479483257}
    base {ThinkGeo.MapSuite.Core.AreaBaseShape}: {829995.080935478,302615.353243947,859293.954696049,273316.479483257}
    Height: 29298.873760690098
    LowerLeftPoint: {829995.080935478,273316.479483257,0}
    LowerRightPoint: {859293.954696049,273316.479483257,0}
    UpperLeftPoint: {829995.080935478,302615.353243947,0}
    UpperRightPoint: {859293.954696049,302615.353243947,0}
    Width: 29298.873760570888
Did I miss something ?
Guillaume
First, the question you have is related to the Services edition, not the Desktop edition and this is why I moved your question to the adequate forum.
  Can you give us a little more detailed explanations of what you are doing with generating pictures for the cache system? Can you send us the code related to that? I think this is going to help us determining more precisely where the problem might reside. Thank you.
Sorry for the lack of informations.
I manage to recreate the problem in a very sample.
The version of MapSuite I use is 3.1.299
The sample I created is about 6.5Mb, with Maps. Here I can only send up to 500 Kb files.
How can I send you this sample ?
Guillaume.
Please contact ThinkGeo Support at support@thinkgeo.com. For large files, we setup the users with an FTP account they can upload the files to but in your case, I think that 6.5 Mb is not too large to be emailed to Support. Thank you.
