This might be very simple.
I cannot get the map show all features from the shape file. The shapefile has over 3000 rows of data but it is only show 115 on the map. Is this a setting problem or is there a problem with the shapefile? I just don't want to call the person who gave me the shapefile before comfirming it is the problem with the shapefile.
I have tried using the Map Suite Explorer and also in my only .net application, it is only show about the same amount of dots on the screen. I can easily tell the different between 3000 dots and 115 dots. Is there a property I can set to have it show all the dots. I do get an error when I use Map Suite Explorer to build the index, but it loads fine after I restart Map Suite Explorer, just not showing all the features.
Any idea?
