Map is not showing
Hello
This is my Code......
Dim geoEngine = New GeoCodeEngine("C:\Program Files\ThinkGeo\Map Suite Geocode USA Evaluation Edition 2.0\GeoCodeIndex", False)
Dim geoCodeResult As New GeoCodeResult()
Dim geoCodeUSASettings = GetSettingsFromXML()
geoCodeResult = geoEngine.AdvancedGeoCode("1617 St. Andrews Dr.", "Lawrence", " KS", "66047", geoCodeUSASettings)
Dim Pp As New PointShape()
Pp.X = Convert.ToDouble(geoCodeResult.Longitude)
Pp.Y = Convert.ToDouble(geoCodeResult.Latitude)
ViewState("Pp") = Pp
Map1.MapUnit = GeographyUnit.DecimalDegree
'Map1.CurrentExtent = New RectangleShape(-97.68367, 30.29563, -97.67009, 30.28538)
'Map1.CurrentExtent = New RectangleShape(-180.0, 83.0, 180.0, -90.0)
'Map1.CurrentExtent = New RectangleShape(-170.0R, 80.0R, 170.0R, -80.0R)
Map1.CurrentExtent = New RectangleShape(-97.7458275477605, 30.2976947428081, -97.728208518133, 30.2851233270739)
Dim streetLayer As New ShapeFileFeatureLayer("C:\Program Files\ThinkGeo\Map Suite Web Evaluation Edition 3.0\Samples\VB Samples\SampleData\USA\Austin\austinstreets.shp")
streetLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle = LineStyles.LocalRoad2
streetLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
streetLayer.DrawingMarginPercentage = 80
Dim streetTxLayer As New ShapeFileFeatureLayer("C:\Program Files\ThinkGeo\Map Suite Web Evaluation Edition 3.0\Samples\VB Samples\SampleData\USA\Austin\austinstreets.shp")
streetTxLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.Highway5("FENAME")
streetTxLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
streetTxLayer.DrawingMarginPercentage = 80
Dim rangeLayer As New InMemoryFeatureLayer()
rangeLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimpleCircleStyle(GeoColor.SimpleColors.Red, 20)
rangeLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.FillSolidBrush.Color = GeoColor.FromArgb(100, 200, 255, 200)
rangeLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle.OutlinePen.Color = GeoColor.StandardColors.LightGreen
rangeLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
rangeLayer.InternalFeatures.Add(New Feature(Pp))
Map1.StaticOverlay.Layers.Add("StreetLayer", streetLayer)
Map1.StaticOverlay.Layers.Add("StreetTxLayer", streetTxLayer)
Map1.DynamicOverlay.Layers.Add("RangeLayer", rangeLayer)
Map1.MarkerOverlay.Columns.Add(New FeatureSourceColumn("FENAME"))
Map1.MarkerOverlay.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
Map1.CenterAt(Pp)
its not give any error but not showing a map please see the attach screen shop
Please help me what is problem in my code.
Vivek,
I changed your message a bit just to make the code shows better.
We tried your code and found nothing displayed except the blue background. We figured it out and found that’s because the current extent is out of the range or Austin, there isn’t have any data so there is nothing to show.
Didn’t see the attached snapshot, if you still have problem can you also provide that?
