Map.Mode
Since Map.Mode has been removed, how do I now work around this? I had an external tool bar that would toggle the mode as necessary.
Edit: A quick and simple look at the change log and the work arounds points to the right direction. All set.
Nelson,
Glad you make it yourself. Here still want to post the latest version's change log so other guys can see it.
Map.Mode property is removed
Description:
In version 3.1.0, the Map.Mode property is removed. The Map.EditOverlay is responsible for anything related to shape editing. Please use the Map.EditOverlay.TrackMode instead. Note the Mode.Normal is replaced by the TrackMode.None which means the editing mode is disabled, we’ll update the broking change paper soon.
In Version 3.0.131:
        Map1.Mode = Mode.Normal;
        Map1.Mode = Mode.TrackPoint;
        Map1.Mode = Mode.TrackLine;
        Map1.Mode = Mode.TrackPolygon;
        Map1.Mode = Mode.TrackRectangle;
        Map1.Mode = Mode.TrackSquare;
        Map1.Mode = Mode.TrackCircle;
        Map1.Mode = Mode.TrackEllipse;
        Map1.Mode = Mode.EditShape;
In Version 3.1.0:
        Map1.EditOverlay.TrackMode = TrackMode.None;
        Map1.EditOverlay.TrackMode = TrackMode.Point;
        Map1.EditOverlay.TrackMode = TrackMode.Line;
        Map1.EditOverlay.TrackMode = TrackMode.Polygon;
        Map1.EditOverlay.TrackMode = TrackMode.Rectangle;
        Map1.EditOverlay.TrackMode = TrackMode.Square;
        Map1.EditOverlay.TrackMode = TrackMode.Circle;
        Map1.EditOverlay.TrackMode = TrackMode.Ellipse;
        Map1.EditOverlay.TrackMode = TrackMode.Edit;
