Map Parser not found!
I am using Map suit web edition with C# (VS 2010). I am also using .Net Nuke (content management system). when i run the page through .Net Nuke, i got following error: ' Map parser not found', i dont know where is problem. can anybody explain why this happen.
Other thing is , the page was running successfully some days before but now it gives this error.
please help!
Hi aa,
We can't recreate the issue you mentioned, it seems that this issue is happened in "parser_GeoResrouce.axd", you may need to check this file while debugging.
Could you please provide us more information (for example a sample project) to reproduce your issue? We also need to know which web edition version are you using.
Ivan
