Map Projection Method for shapefile over google map
Hi, I am having trouble to put my shapefile layer over google map.
The map display the shape file correct when I only have shape file layer and set the map.CurrentExtent to the boundingbox of the shapefilelayer. However, I am having trouble to put shapefile over google map.
The projection function I use is:
-- begin code
                GoogleOverlay google = new GoogleOverlay("Google Map");
                google.JavaScriptLibraryUri = new Uri(Config.Current.GoogleUri);
                google.GoogleMapType = GoogleMapType.Normal;
                StreetShapeLayer = GetStreetShapeLayer();
                StreetShapeLayer.FeatureSource.Projection = proj4;
                LayerOverlay shapeOverlay = new LayerOverlay("Shape Overlay", false, TileType.SingleTile);
                shapeOverlay.Layers.Add(StreetShapeLayer);
                shapeOverlay.TransitionEffect = TransitionEffect.None;
                Map1.MapBackground.BackgroundBrush = new GeoSolidBrush(GeoColor.GeographicColors.DeepOcean);
                Map1.CurrentExtent = new RectangleShape(Config.Current.minX, Config.Current.maxY, Config.Current.maxX, Config.Current.minY);
                Map1.CustomOverlays.Add(shapeOverlay);
--end code
The map is Guam's map, I have tried different Srid, and different Get_ParametersString functions, none of them work, the map only show Guam Island on google map, none of the features in the shape file is shown. I guess it wasn't project correctly.
Below is the projection data in .prj file
PROJCS["Guam_Geodetic_Network_1993",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",100000.0],PARAMETER["False_Northing",200000.0],PARAMETER["Central_Meridian",144.75],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",13.5],UNIT["Meter",1.0]]
Help!
According to the projection seen in the PRJ file, the shapefile is not in WGS84 projection so, you should not use EPSG 4326. You need to use another projection string for proj4. Please, look at the Spatial Reference web site to see what projection string you need.
 I looked myself in the Spatial Reference web site to see if there is the proj4 string that correspond exactely to the string you have in the PRJ file but I could not find. You need to see with the source of the shapefile if they can help you with that. If you have not luck on that side, please send us the entire shapefile with the prj file and we will see what we can do to find the proper proj4 string.
 spatialreference.org/
I went to the spatialreference site and found the project string. It is working perfectly now.
Thanks for your help.
You are welcome. Let us know if you need more help.
