When I have a PostgreSqlFeatureLayer, the PostgreSQL database is on my local machine, there are about 40,000 point symbols in this layer. When I add on this layer, the map refreshes very slow, if I do a track zoom-in, it became blur immediately, then took 25 seconds to display properly; if I click on a zoom-out or zoom- in button, it took 24 seconds to finish. It is also very slow to pan around the map.
Tried to export the data into an ESRI shape file, it took about 4 seconds to do the same jobs.
Is this normal or am I doing sth wrong? In our scenario, there could be more then tens of millions of data in the database. How to speed up?
Did you create the index for your Postgre database? Please try the following query to generate the index. (replace the tablename and GeometryColumnName with your corresponding ones)
create index tablename_sidx on tablename using gist (GeometryColumnName)
Rose, I am not very sure what the extent you are using for the spatial query, and how many records will be returned. It takes me 11.93 seconds to get all the 194,261 records from my postgre. Please try the following SQL statement to test the performance: SELECT AsBinary(“GeometryColumnName”) FROM TableName WHERE GeomFromText(‘WKT’, SridNumber) && “GeometryColumnName”; You need to replace “GeometryColumnName”, “TableName”, “WKT” and “SridNumber” with your corresponding ones. The “GeometryColumnName” is the shape column in your table, “WKT” is the well known text to show the current extent, so you can use Map.CurrentExtent.GetWellKnownText() to replace it, “SridNumber” is the EPSG number, for example: 0 for null, 4326 for DecimalDegree or 900913 for GoogleMap. The SQL statement is for a spatial query, getting shapes in binary by the specified extent. I think this statement can tell whether it’s a postgre server’s problem or PostgreExtension’s problem. If the speed here is also very slow, then it must be some problems with the server.
Please get the latest PostGreExtension from the following post and try the SQL statement within ExecuteSqlQuery to compare the speed difference. If it's slower, could you double check some other aspects like network speed which might affect the result?
The SQL statement: SELECT AsBinary("GeometryColumnName") FROM TableName WHERE GeomFromText('WKT', SridNumber) && "GeometryColumnName";
It does not work in both PostgreExtensions, it complains "Can not find the geometry column in table : 'vesselsview'".
I tried this statement: SELECT * FROM TableName WHERE GeomFromText('WKT', SridNumber) && "GeometryColumnName"; it works. With 736,306 records in my table, it took 46 seconds instead of 50 seconds with the new PostGreExtension. My database is installed on the developer's machine, same machine with the application, so no network speed issue.
Once the data is displayed on the map, it took 26 seconds to zoom in/out. Is this normal?
I made a performance test in which I get all the records within one rectangle and draw them out, here is the result.
Records within the rectangle Drawing Time(s) Rectangle 1 40,000 1.5 Rectangle 2 72,943 2.6 Rectangle 3 163,000 5.7 Rectangle 4 194,261 6.1
The Postgre server is running on the same machine. The Drawing Time includes pulling data from database and rendering them out.
As there is linear relationship between Records Count and Drawing Time, we can say if the specific extent contains 736.306 records, the drawing time will be around 25 seconds. Now just wonder how many records you want to display at a time in your case? If there are a lot of records, 26 seconds makes sense (although that doesn’t make much sense to display too many records at a time); if the records are fewer, the time should be reduced linearly.
