HI,
I recently switched Map Routing from 4.5 to 5.0 and have encouterred some issues.
In 4.5, a RoutingResult object seems to contain these three info: Features, Route.Lines, and RouteSegments, and all those seems to correspond each other. See the picture below.
(Rendered the result)
However, in 5.0, the same line of code with the same routing file gives different and results as below. The Line count is different from the RouteSegments
When the result is renderred, it is like,, Oh, only three pictures can be attached? let me continue.
