Map Suite 4.0 application using Composite UI Application Block Architecture
Can you give me an example that shows a windows desktop  edition ( Or Service Edition) map suite 4.0 application based on the Composite UI Application Block Architecture?  The architecture can handle a background thread receiving GPS coordinates of monitored objects from backend server, while at the same time handles GUI customer requests.
I am interested in the architecture's migration path from Map Suite desktop  edition 2.55.5 to Map Suite Desktop 4.0 or Map Suite Service 4.0 (whichever is less complicated).  Does GeoThink provide such a migration path in terms of white paper etc?
Thanks for sheding light on this practical aspect of Map Suite application.
Franklin
Franklin,
 We don’t have any sample to show that, did you try to do it by your self, if you encouter any problem, please let us know, and we can test it to find what happened based on your sample code.
 And I am not sure what’s your meaning about migration path from 2.55.5 to 4.0, do you mean for example, you already have a sample which is using 2.55.5, and now you want to migrate it to based on 4.0, The 3.0 or 4.0 is brand new design so that it not compatiable to 2.55.5, it has many breaking-changes, but I think you still can convert it to 4.0 with our help.
