Map Suite Explorer Problem
I'm using Web Edition evaluation version 3.1.16. I have a small problem with the Map Suite Explorer.
When I try to open a shapefile, it complains about the lack of an spatial index. I let it create the index and open the file. But, it does this everytime I try to open the file regardless of the existence of the index files (*.idx and *.ids, I believe).
Somehow, it seems not to realize the index files are there. Using the resultant index with the Map Suite does not present any problems though.
Best regards,
Hakan Çelik
Hakan,
 We recreated it and you are right that’s a problem. I have added it to our issues system and we will work on it. Thanks for reporting!
