Map Suite Explorer Query Functionallity Not Working on Vista 64 Bit
Hi, I like to use Map Suite Explorer to look at my shapefiles from time to time, and I really like the functionality where I can right click on the layer in the right panel and pop up the window where I can write a SQL Query against the DBF that comes with the shapefille.  However since I upgraded to a 64 bit OS (Vista), this functionality doesn't work anymore.  It says the OLEDB dependencies aren't installed.   Is there any way to fix this, or will the next version that comes out have this issues resolved?
I know Map Suite Explorer can read the DBF somehow, because if I click on a feature in Info mode it will show the attributes from the DBF.  So it seems to be isolated to the SQL query part of Map Suite Explorer.
Clint,
 Thanks for your post!
 This is an well-known issue to us! We cannot support it unless Microsoft supported it in 64-bit operating system.
 Following is some similar post, if you are interest, just take a look.
 gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5825/afv/topic/afpgj/1/Default.aspx#5825
