Map Suite SaveState and LoadState
Hi @Ethan
I use a map control to load a shape map file, I use the map control method SaveState and LoadState.
code:
private byte mapState;
private void save_Click(object sender, RoutedEventArgs e)
mapState = MapControl.SaveState();
    private void load_Click(object sender, RoutedEventArgs e)
        if(mapState != null)
              MapControl.LoadState(mapState);
 The saved state can be successful, but there is an empty reference error when loading.
regards,
ZhangMing.
Hi ZhangMing,
I think the API SaveState and SaveState should have some problem, our developer will look into it.
Please try this workaround for now:
byte[] mapState;
    private void button_Click(object sender, RoutedEventArgs e)
        GeoSerializer serializer = new GeoSerializer();
        MemoryStream stream = new MemoryStream();
        serializer.Serialize(map, stream);
        mapState = stream.ToArray();
    private void button1_Click(object sender, RoutedEventArgs e)
        MemoryStream stream = new MemoryStream(mapState);
        WpfMap map = serializer.Deserialize(stream) as WpfMap;
Hi @Ethan
thanks. i will try.
ZhangMing
Hi ZhangMing,
