Map Suite Vehicle Tracking Starter Kit Question
Hi Support,
Is the Map Suite Vehicle Tracking Starter Kit compatible with the MVC Edition? My project requires such functionality. I’m really interested with the client demo but it has no trial that I can play with.
Please let me know that if I buy it, I can customize it according to my requirements:
- it needs to be compatible with HTML5,
- will be run on iPad,
- will connect to Web API with Entity Framework 4.5,
- should support saving the tracked data locally such as HTML5 local storage
- performance should be quick with minimum lag
Benito Gamas
Hi Benito,
 Thanks for your post.
 To some extent, the Ajax version Vehicle Tracking Starter Kit is compatible with the Mvc Edition, but as we know, it’s just a Ajax version based on Web Edition, not Mvc Edition, if we would like to port it to Mvc Edition, I guess we need to change something, but good thing is that the most of the code of Ajax Version is JavaScript, which can be used in Mvc Edition directly.
 And about the rest question, following are the answers one by one:
 - MVC Edition could be compatible with HTML5.
 - MVC Edition could run on the iPad.
 - based on test we have made with Framework 4.5, it is running ok.
 -         MVC Edition could support saving the tracked data with HTML5 local storage.
 - For the test we have made on mvc, it is fluent.
 Best Regards
 Summer
