I am not sure where to go from here but I have downloaded the newest update for the Desktop Edition and have set the threading model to SingleThreading and I am still getting exceptions. I am doing as Microsoft recommends for threading in that I raise an event and the map winforms object is subscribed to that event. Worked fine in 2.0 and still works fine in 2.0 but does not work in 3.0.
I am now getting the following exception:
at System.Drawing.Pen.get_PenType()
at System.Drawing.Pen.get_Brush()
at ThinkGeo.MapSuite.Core.GdiPlusGeoCanvas.x80259444712de393()
at ThinkGeo.MapSuite.Core.GdiPlusGeoCanvas.FlushCore()
at ThinkGeo.MapSuite.Core.GeoCanvas.Flush()
at ThinkGeo.MapSuite.DesktopEdition.LayerOverlay.xa6cb874f7090c07f(GeoCanvas x31c084515ae9393f)
at ThinkGeo.MapSuite.DesktopEdition.LayerOverlay.DrawCore(GeoCanvas canvas)
at ThinkGeo.MapSuite.DesktopEdition.Overlay.Draw(GeoCanvas canvas)
at ThinkGeo.MapSuite.DesktopEdition.xf0380b1a0bc40ca6.StartDraw()
at ThinkGeo.MapSuite.DesktopEdition.x601a5561df898600.StartDraw(Int32 tileWidth, Int32 tileHeight, RectangleShape tileExtent, Collection`1 overlays)
at ThinkGeo.MapSuite.DesktopEdition.x601a5561df898600.RefreshDynamic(Collection`1 overlays)
at ThinkGeo.MapSuite.DesktopEdition.x65fdca92d79c01f5.RefreshDynamic()
at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.RefreshDynamic()
at EPIC.Works.LiveMap.asset_PositionAdded(Object sender, AssetPositionAddedEventArgs e) in C:\Users\Curtis\Documents\Visual Studio 2008\Projects\EPIC Works 3\EPIC Works\LiveMap.cs:line 191
at EPIC.Works.BusinessObject.AbstractAsset.OnPositionAdded(AssetPositionAddedEventArgs e) in C:\Users\Curtis\Documents\Visual Studio 2008\Projects\EPIC Works 3\EPIC Works\BusinessObject\AbstractAsset.cs:line 175
at EPIC.Works.BusinessObject.MobileAsset.AddPosition(Position position) in C:\Users\Curtis\Documents\Visual Studio 2008\Projects\EPIC Works 3\EPIC Works\BusinessObject\MobileAsset.cs:line 56
at EPIC.Works.BusinessObject.MobileAsset.liveUpdate_DoWork(Object sender, DoWorkEventArgs e) in C:\Users\Curtis\Documents\Visual Studio 2008\Projects\EPIC Works 3\EPIC Works\BusinessObject\MobileAsset.cs:line 75
I have also included the two methods which appear to be causing the issue. I have alot of the code commented in the one in an attempt to isolate the issue.
Any ideas?
Curtis
PositionAdded
private void asset_PositionAdded(object sender, AssetPositionAddedEventArgs e) {
GeoPen pen = new GeoPen(new GeoSolidBrush(GeoColor.StandardColors.Blue));
pen.SetLineCap(DrawingLineCap.Round, DrawingLineCap.Round, GeoDashCap.Round);
pen.Width = 6;
//Hashtable synchronizedAssetLines = Hashtable.Synchronized(assetLines);
//if (enableTruckTrack) {
// InMemoryFeatureLayer truckTrackLayer = (InMemoryFeatureLayer)Map.FindFeatureLayer(e.Position.Asset.AssetId.ToString() + "|Track");
// if (truckTrackLayer == null) {
// LineShape lineShape = new LineShape();
// lineShape.Vertices.Add(new Vertex(e.Position.convertToDecimalDegrees(e.Position.Longitude), e.Position.convertToDecimalDegrees(e.Position.Latitude)));
// synchronizedAssetLines.Add(e.Position.Asset.AssetId.ToString(), lineShape);
// truckTrackLayer = new InMemoryFeatureLayer();
// truckTrackLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle = new LineStyle(pen);
// truckTrackLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
// Map.DynamicOverlay.Layers.Add(e.Position.Asset.AssetId.ToString() + "|Track", truckTrackLayer);
// } else {
// // If the hashtable contains the asset then we need to generate the layer and remove the asset from the hashtable.
// if (synchronizedAssetLines.ContainsKey(e.Position.Asset.AssetId.ToString())) {
// LineShape lineShape = (LineShape)synchronizedAssetLines[e.Position.Asset.AssetId.ToString()];
// synchronizedAssetLines.Remove(e.Position.Asset.AssetId.ToString());
// truckTrackLayer.InternalFeatures.Add("Track", new ThinkGeo.MapSuite.Core.Feature(lineShape));
// } else {
// LineShape lineShape = (LineShape)truckTrackLayer.InternalFeatures["Track"].GetShape();
// truckTrackLayer.InternalFeatures["Track"] = new ThinkGeo.MapSuite.Core.Feature(lineShape);
DrawTruck(e.Position);
Map.RefreshDynamic();
DrawTruck
private void DrawTruck(EPIC.Works.BusinessObject.Position position) {
InMemoryFeatureLayer truckLayer = null;
Dictionary<String, String> dictionary = new Dictionary<String, String>();
dictionary.Add("LAT", position.convertToDecimalDegrees(position.Latitude).ToString());
dictionary.Add("LONG", position.convertToDecimalDegrees(position.Longitude).ToString());
dictionary.Add("SPEED", "18mph");
dictionary.Add("HEADING", position.Heading.Trim());
dictionary.Add("NAME", position.Asset.AssetDescription);
if(Map.FindFeatureLayer(position.Asset.AssetId.ToString()) == null){
truckLayer = new InMemoryFeatureLayer();
truckLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.PointType = PointType.Bitmap;
truckLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle.Image = new GeoImage("C:\\dumptruck.png");
//truckLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.CreateMaskTextStyle("[NAME]\nHeading: [HEADING]\nSpeed: [SPEED]", "Arial", 8, DrawingFontStyles.Bold, GeoColor.StandardColors.Black, GeoColor.StandardColors.Black, 2, -34, -30);
truckLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
truckLayer.InternalFeatures.Add("Truck", new ThinkGeo.MapSuite.Core.Feature(new PointShape(Convert.ToDouble(dictionary["LONG"]), Convert.ToDouble(dictionary["LAT"])), dictionary));
Map.DynamicOverlay.Layers.Add(position.Asset.AssetId.ToString(), truckLayer);
} else {
truckLayer = (InMemoryFeatureLayer)Map.FindFeatureLayer(position.Asset.AssetId.ToString());
PointShape pointShape = new PointShape(Convert.ToDouble(dictionary["LONG"]), Convert.ToDouble(dictionary["LAT"]));
pointShape.Id = "Truck";
truckLayer.Open();
truckLayer.EditTools.BeginTransaction();
truckLayer.EditTools.Update(pointShape, dictionary);
truckLayer.EditTools.CommitTransaction();
truckLayer.Close();
