Map1.CustomOverlays collection empty
I am trying to set up my program so that user input is reflected by changes to the map overlays, however the map.overlay collection is empty such that I cannot edit my existing layers/overlays.  I have no idea why this is happening.
In the code below int c and int s both have values of zero.  However, the map itself has 7 overlays, including the static overlay, all added under the page_load method.  Why when accessed under the callback are the collections empty??
using System;
using System.Collections.Generic;
using System.Collections.ObjectModel;
using System.Data;
using System.Linq;
using System.Web;
using System.Web.UI;
using System.Web.UI.WebControls;
using System.Web.Services;
using ThinkGeo.MapSuite.Core;
using ThinkGeo.MapSuite.WebEdition;
namespace Market_Share_IQ
    public partial class MainPage : System.Web.UI.Page, ICallbackEventHandler
        Map_Overlays OverlayClass;
            OverlayClass = new Map_Overlays();
            lblSession.Text = Session["SessionId"].ToString();
            if (!IsPostBack)
                String cbReference = Page.ClientScript.GetCallbackEventReference(this, "arg", "ReceiveServerData", "context");
                String callbackScript = "function CallServer(arg, context)" + "{ " + cbReference + ";}";
                Page.ClientScript.RegisterClientScriptBlock(this.GetType(), "CallServer", callbackScript, true);
                Map1.CurrentExtent = OverlayClass.GetExtent(Session["SessionId"].ToString());
                Map1.StaticOverlay.Layers.Add(OverlayClass.DefineBaseMap());
                GeoCollection<Overlay> MapOverlays = OverlayClass.GetOverlays(Session["SessionId"].ToString());
                foreach (Overlay mapLOLs in MapOverlays)
                    Map1.CustomOverlays.Add(mapLOLs);
        #region ICallbackEventHandler Members
        string clearEditOverlayResult = string.Empty;
        public string GetCallbackResult()
            return clearEditOverlayResult;
        public void RaiseCallbackEvent(string eventArgument)
            if (eventArgument == "ClearEditOverlay")
                int c = Map1.CustomOverlays.Count;
                int s = Map1.StaticOverlay.Layers.Count;
                Map1.CustomOverlays.Clear();
                LayerOverlay PenetrationOverlay = new LayerOverlay();
                PenetrationOverlay.Redraw();
                clearEditOverlayResult = "ClearEditOverlaySuccess";
        #endregion
Eric,
 I have replied your ticket.
Don,
 I was wrong yesterday, the JavaScript function did not clear the map.  I reopened the trouble ticked, just wanted to make sure you were aware.
 Thnak you,
 Eric
Eric,
 Thanks for your update, I will read your response.
