MAPINFO TAB,MWS support
I'm evaluating the component for a customer.
I have a full MapInfo project with a MapInfo Workspace (.mws), map files etc...
Firstly I want to know if your application could load all the layers from the mws workspace file.
Secondly I have a look at the sample on the wiki and all the characteristics of the layer like colours, line style (etc..)
seems to be manually  coded : I want my application to display the layers as in MapInfo, is it possible to load them without manually harcode those characteristics ?
Thank you for your answer.
Regards.
 anyone could help me about this ?
 Brian
Sumant,
 I think MapSuite probably not support .mws files, however it supports .tab files which are also from MapInfo, if you can convert it to .tab files, I think you ca load them.
 And our MapSuite is a framework for developers but not for normal users, so you need to write code to call our APIs to set colors and styles, I think that make sense. Everything is under you control, so that it makes your application flexible, you can do anything you want.
