MapShapes translated with map extent translation
When I translate the CurrentExtent of the map by a certain offset, the overlying InMemoryFeatureLayer "moves" with it. i.e, the mapshapes in the InMemoryFeatureLayer are also translated by the same offset. Hence their coordinate point values change with each translation.
What I need is for the mapshapes to stay fixed on their original point coordinates. I use the translation as a means of panning programmatically. "PanTo" does not fulfill my panning requirements.
help would be much appreciated. Many thanks
my mistake, just the opposite is true. what i need is for the mapshapes to move with the translation and not stay positioned on one static screenpoint.
resolved. On changing the extent of the map, the Overlay holding the layers with mapshapes needs to be refreshed manually.
Christian,
 Sorry for replying delay, that’s a good news to hear you resolved it, if you encounter any new problems please let me know again,
 Scott,
