Wanted to display column data in a menu item when generating a contextmenu. I use the format:
[#columndatafielname#]
All markers contextmenu's display the same first marker's columndata value that was added to the layer? Using the above format works fine when used for a marker popup.
As a sidenote, what I am trying to do is be able to right click a marker and have a panel show up with the id, x and y of the marker. The user would then be able to change the x and y and have the marker would move. I could not find a method to get the feature/marker id at the server when right clicking so was going to use the location.innerhtml with the id as part of the html to be parsed and thus used to find the marker for the move.
