Marker Overlay Only visible after drag/pan/zoom
I have map that changes and loads a marker overlay (and other overlays) via a callback, then redraws the overlays on the client side via the layer.redraw(true) function.
My problem is that the marker overlay is not visible unless I move the map (drag it), at which point the markers are instantly visible.  I can confirm the markers are being rendered and are being drawn.
I have tried using simplemarker overlay as well as inmemorymarker overlay and have the same problem.
Has anyone seen this before?
Hello Eric,
 Thanks for your post, I think this problem I have met before, could you please provide your code to help us find the root cause?
 I’m appreciate if you can provide a sample.
 Hey Gary,
I have upoladed all my code and more explanation under a trouble ticket that has been assigned to Don.
I have not heard from him in a few days, and if you have seen this before perhaps you could be useful.
I am using AJAX to populate and refresh the overlays because there was a problem with Server.Transfer method clearing the map.overlay collections.
You guys released a daily build for me to correct the server.transer problem, but I still need this marker problem fixed.
My trouble ticket is ticket number 5492, Don has been working on it so far.
Eric
Hello Eric,
 Ok, thanks for your data and sample, Don will try to resolve your problem in the ticket as soon as possible.
