Hi
I have added a marker overlay onto my map and a pop when the user hovers over
This is sample code which i have used
StoresMarkerOverlay.FeatureSource.InternalFeatures.Add(myStore.ColumnValues("Id"), myStore)
StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.ContentHtml = "[#StoreName#]([#StoreCode#])]"
StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.HasCloseButton = True
StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.Width = 200
StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.Height = 60
StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.BackgroundColor = GeoColor.StandardColors.Green
StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.BorderColor = GeoColor.StandardColors.White
StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.BorderWidth = 1
StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage = New WebImage("…/Images/HH.png")
StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
I am not sure why the popup works on my Development server and not on my Production server
Marker popup not showing on production server but showing on Development server
Hi Ismail,
I don’t think your code have problem.
Please make sure your two server use same version, then make sure after you deployment whether all source include your images can be found.
And whether the necessary dlls you are using is plot in correct folder in production server.
