I want to display a series of markers, based on a TAB data set. Each marker should have an individual popup showing data from a column.
I've created a class "ColumnBasedMarkerStyle", with a constructor taken a column name as argument, and an overriden function GetMarkers().
But the marker layer doesn't display anything, but I'm not sure whether the error's in the class definition, or in the class invocation.
Any help is appreciated. My code is below.
Public Class ColumnBasedMarkerStyle
    Inherits MarkerStyle
    Private m_ColumnName As String
    Public Sub New(ByVal cn As String)
        m_ColumnName = cn
    End Sub
    Public Overrides Function GetMarkers(ByVal fts As System.Collections.Generic.IEnumerable(Of Feature)) _
        As System.Collections.ObjectModel.Collection(Of Marker)
        Dim m As New Marker
        Dim mks As New System.Collections.ObjectModel.Collection(Of Marker)
        Dim msg As String = "Info:<ul>"
        If m_ColumnName = "" Then
            msg += "<li>NO information</li>"
        Else
            For Each ft In fts
                msg += "<li>" + ft.ColumnValues(m_ColumnName).ToString() + "</li>"
            Next
        End If
        msg += "</ul>"
        m.Popup.ContentHtml = msg
        mks.Add(m)
        Return mks
    End Function
End Class
Dim mo As New InMemoryMarkerOverlay()
myDataset.FeatureSource.Open()
For Each ft In myDataset.FeatureSource.GetAllFeatures(ReturningColumnsType.AllColumns)
    mo.Features.Add(ft)
Next
myDataset.FeatureSource.Close()
mo.Name = "My markers"
mo.IsVisible = False
mo.IsBaseOverlay = False
mo.IsVisibleInOverlaySwitcher = True
mo.ZoomLevelSet.ZoomLevel01.CustomMarkerStyle = New ColumnBasedMarkerStyle("NAME")
mo.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
Map1.CustomOverlays.Add(mo)
