Hi James,
As explained earlier in the thread, I'm using a custom marker style class to enable individual column based popups.
The markers are added to an InMemoryMarkerOverlay via a reprojected vector layer, but the reprojection seems to be in order, producing correct coordinates for the markers.
Here how the two layers are built and added to CustomOverlays:
Public Class ColumnBasedMarkerStyle
    Inherits ThinkGeo.MapSuite.WebEdition.MarkerStyle
    Private m_ColumnName_Name As String = ""
    Private m_ColumnName_WebImage As String = ""
    Public Sub New(ByVal cn As String, ByVal wi As String)
        m_ColumnName_Name = cn
        m_ColumnName_WebImage = wi
    End Sub
    Public Overrides Function GetMarkers(ByVal fts As System.Collections.Generic.IEnumerable(Of Feature)) _
        As System.Collections.ObjectModel.Collection(Of Marker)
        Dim mks As New System.Collections.ObjectModel.Collection(Of Marker)
        For Each ft In fts
            Dim m As New Marker()
            m.IsVisible = True
            Dim baseShape As BaseShape = ft.GetShape()
            If TypeOf baseShape Is PointShape Then
                m.Position = TryCast(baseShape, PointShape)
            Else
                m.Position = TryCast(baseShape.GetCenterPoint, PointShape)
            End If
            If m_ColumnName_WebImage = "" Then
                m.WebImage = New WebImage("/images/red_point.gif")
            Else
                m.WebImage = New WebImage(ft.ColumnValues(m_ColumnName_WebImage))
            End If
            With m.WebImage
                'hardcoded for red_point.gif !
                .ImageOffsetX = -3.5F
                .ImageOffsetY = -3.5F
            End With
            Dim msg As String = ""
            If m_ColumnName_Name = "" Then
                msg = "<b>Uden navn:</b><hr/>"
            Else
                msg = "<b>" + ft.ColumnValues(m_ColumnName_Name).ToString() + "</b><hr/>"
            End If
            With m.Popup
                .BorderWidth = 2
                .Width = 300
                .Height = 250
                .ContentHtml = msg
            End With
            mks.Add(m)
        Next
        Return mks
    End Function
End Class
Here the definition of the custom marker style object:
Dim skulpturer = New TabFileFeatureLayer("C:\Maps\MapInfo\Skulpturer_webgis.TAB", "ID", "OGRSchema")
With skulpturer.ZoomLevelSet.ZoomLevel01
    .DefaultPointStyle = PointStyles.CreateSimplePointStyle(PointSymbolType.Circle, New GeoColor(0, 0, 255), 10)
    .DefaultTextStyle = TextStyles.Capital2("NAVN")
    .ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
End With
skulpturer.IsVisible = True
skulpturer.FeatureSource.Projection = New ManagedProj4Projection( _
                                    ManagedProj4Projection.GetEpsgParameters(25832), _
                                    ManagedProj4Projection.GetGoogleMapParameters())
Dim ptsOverlay = New LayerOverlay("Odense skulpturer P", False, TileType.SingleTile)
ptsOverlay.Layers.Add(skulpturer)
ptsOverlay.IsVisible = True
Map1.CustomOverlays.Add(ptsOverlay)
Dim mo As New InMemoryMarkerOverlay("MyMarkers")
skulpturer.FeatureSource.Open()
mo.FeatureSource.Open()
For Each c In skulpturer.FeatureSource.GetColumns()
    mo.Columns.Add(New FeatureSourceColumn(c.ColumnName, c.TypeName, c.MaxLength))
Next
For Each ft In skulpturer.FeatureSource.GetAllFeatures(ReturningColumnsType.AllColumns)
    mo.Features.Add(ft) 'transfers column data ??
Next
mo.FeatureSource.Close()
skulpturer.FeatureSource.Close()
mo.Name = "Odense skulpturer M"
mo.IsVisible = True 'False 'for now
mo.IsBaseOverlay = False
mo.IsVisibleInOverlaySwitcher = True
With mo.ZoomLevelSet.ZoomLevel01
    .CustomMarkerStyle = New ColumnBasedMarkerStyle("NAVN", "") ', mo.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage)
End With
Map1.CustomOverlays.Add(mo)
I'm attaching the "Skulpturer_webgis" MapInfo TAB.
TIA
Skupturer_webgis.zip (14.8 KB)
