I Disovered that the exception is not thrown in a modified HowDoi project
I think it difficult to debug/ find the errors since the exception information does not give insight to for exampl which layer is causing the problem. The exception is thrown within Microsoft maui code so its not possible to change this code. It it possible to improve logging / exception handlig giving better insight to the problem in hand?
The problem description:
I load a shapefile layer in maps, when opening the map there is an exceptionLarvikMotorvei.zip (24.3 KB)
private async Task F0Q_003D
private void AddShapeLayer(string dataDirectory, string? s )
if (s == null)
s = "shp4326.shp";
var dashedPen = new GeoPen(GeoColors.Green, 5);
dashedPen.DashPattern.Add(1);
var parksOverlay = new LayerOverlay();
MapView.Overlays.Add(parksOverlay);
parksOverlay.Opacity = 0.5;
var shapePathFilename = Path.Combine(dataDirectory, "Data", "Shapefile", s);
ShapeFileFeatureLayer.BuildIndexFile(shapePathFilename);
var parksLayer = new ShapeFileFeatureLayer(shapePathFilename)// "HighAll.shp"))
FeatureSource =
ProjectionConverter = new ProjectionConverter(2276, 3857)
// Add the layer to the overlay we created earlier.
parksOverlay.Layers.Add("Frisco Parks", parksLayer);
parksLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle =
new AreaStyle(dashedPen, new GeoSolidBrush(new GeoColor(64, GeoColors.Green)));
parksLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
private ShapeFileFeatureLayer AddShapeLayer(string shapePathFilename)
// read the projection from .prj file
string projWkt = File.ReadAllText(shapePathFilename.Replace(".shp", ".prj"));
string projString = Projection.ConvertWktToProjString(projWkt);
FeatureSource =
ProjectionConverter = new ProjectionConverter(projString, 3857)
parksLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle =
LineStyle.CreateSimpleLineStyle(GeoColors.Red, 2, true);
return parksLayer;
private async void MapView_OnSizeChanged(object sender, EventArgs e)
if (_initialized)
return;
_initialized = true;
MapView.MapUnit = GeographyUnit.Meter;
// Add ThinkGeo Cloud Maps as the background
var backgroundOverlay = new ThinkGeoRasterOverlay
ClientId = SampleKeys.ClientId,
ClientSecret = SampleKeys.ClientSecret,
MapType = ThinkGeoCloudRasterMapsMapType.Light_V2_X2,
TileCache = new FileRasterTileCache(FileSystem.Current.CacheDirectory, "ThinkGeoRasterCache")
MapView.Overlays.Add(backgroundOverlay);
var overlay = new LayerOverlay();
MapView.Overlays.Add(overlay);
var layer = AddShapeLayer(@"d:\Downloads\LarvikMotorvei\LarvikMotorvei.shp");
overlay.Layers.Add(layer);
// Open the layer and set the map view current extent to the bounding box of the layer.
layer.Open();
MapView.CenterPoint = layer.GetBoundingBox().GetCenterPoint();
MapView.MapScale = MapUtil.GetScale(layer.GetBoundingBox(), MapView.MapWidth, MapView.MapUnit);
await MapView.RefreshAsync();
In fact, I couldn’t recreate your exception. If you still see the exception, you can change the overlay to singleTile, and make sure overlay.DrawingExceptionMode = DrawingExceptionMode.ThrowException
