I created an empty project(.net core) and rewrote the code from the current project. But there was a new mistake “sqlite error 14 unable to open database file”
I think this issue may something with the data path name. Can you try to copy the sample project to a simple English path such as D:\test. If still not work you may need change your windows environment to English one.
Go ahead let us know if this still not working. We could schedule a share screen meeting to dig into more detail.
Roman,
Could you give us a screenshot about your system on performance? I tested with few different environments. It works very well. We must miss some environment.
Thanks Roman,
I can re-produce this issue by change the environment. We have fixed this issue. After you download the sample. You could update the thinkgeo nuget package to the latest one. Then it will work.
