Measure tool results
I would like to know if it is possible to cusomize the result of a measure made with the measure tool ?
In my case it shows a balloon containing "Total Area: 8861.382 km2"
And I would like to translate it in french, is-it possible ?
Thank you for your help.
Hi Gautier,
 You can add the code as below in head part of your aspx page and change the “Total Length:” and “Total Area:” to French for change that.
<script language =javascript>
        var OnMapCreated = function (map) {
            handleMeasurements = function (feature) {
                var units = feature.units;
                var measure = feature.measure.toFixed(3);
                if (feature.order == 1) {
                    html = String.format("<div style=‘font-size:small’>Total Length: <span style=‘color:red’>{0} {1}</span></div>", measure.toString(), units.toString());
                else {
                    html = String.format("<div style=‘font-size:small’>Total Area: <span style=‘color:red’>{0} {1}<sup>2<sup></span></div>", measure.toString(), units.toString());
                if (feature.geometry.CLASS_NAME.indexOf(‘LineString’) > -1) {
                    var length = feature.geometry.components.length;
                    lonLat = { lon: feature.geometry.components[length - 1].x, lat: feature.geometry.components[length - 1].y };
                else {
                    var length = feature.geometry.components[0].components.length;
                    lonLat = { lon: feature.geometry.components[0].components[length - 2].x, lat: feature.geometry.components[0].components[length - 2].y };
                var size = new OpenLayers.Size(450, 200);
                var popup = new OpenLayers.Popup.FramedCloud(‘DistancePopup’, lonLat, size, html, null, true);
                popup.isAlphaImage = true; // fix IE 6.0 problem
                this.map.addPopup(popup);
    </script>
This works great !
Gautier,
 You’re welcome.
