Merge points / extract into one InMemoryFeatureLayer
Hi i have  4 tabfiles, each ~ 1000 points
Added to staticOverlay (displays fine)
Now how can I extract/merge all the points into one  InMemoryFeatureLayer so I can query the the points?
What I need is find feature within a distance
-Niels
Niels,
  If I understand you correctly you will not need to merge all of the layers into a InMemoryFeatureLayer.  Instead you just need to loop through each of your Tab layers and do your query on each layer and then compile the results together.  I don’t think there is any need to add the extra step.  You can find the spatial operation under your TabFeatureLayer.QueryTools.
And it works… Thanks :)
Niels,
   Excellent, let me know how else we can help.
