I just upgraded a project from using 4.5 to 5.5 (build 70) - unsuccesfully unfortunately.
I exchanged the project assembly references to Map Suite, and corrected incompatabilities in the code, and got the solution til build without errors.
But when I run the solution, it errs with a Microsoft JScript error, in some evaluated code (pic 1).
If I press "Ignore", I end up inside "parser_GeoResource.axd" (pic 2), which I assume is something Map Suite generates dynamically.
I even went to the trouble of creating a brand new Default.aspx from scratch, moving the code from the old, but it didn't make any difference.
Help please ?
