Migrating from v13 to v14
hi @Jimmy_Pun,
In your scanario, ArcGisServerRestVectorAsyncLayer is what you need. Here’s a sample for you.
Note: ThinkGeo.Core 14.5.0-beta080 or higher is required.
ArcGisServerRestVectorAsyncLayer_Sample.zip (74.2 KB)
Regarding the offline support, we could implement a WmtsCacheHandler class to handle the caching logic.
Usage:
var wmtsLayer = new WmtsAsyncLayer("wmts_server_url");
wmtsLayer.HttpMessageHandler = new WmtsCacheHandler("WmtsCache",
                new HttpClientHandler() { AutomaticDecompression = DecompressionMethods.GZip | DecompressionMethods.Deflate });
WmtsCacheHandler.cs
public class WmtsCacheHandler : DelegatingHandler
    private readonly string _cacheRoot;
    public WmtsCacheHandler(string cacheFolder, HttpMessageHandler innerHandler)
        : base(innerHandler)
        _cacheRoot = cacheFolder;
        if (!Directory.Exists(_cacheRoot)) Directory.CreateDirectory(_cacheRoot);
    protected override async Task<HttpResponseMessage> SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)
        string url = request.RequestUri.ToString();
        bool isCapabilities = IsCapabilitiesRequest(url);
        // Create a specific path for the capabilities file
        // We hash the base URL to ensure different services don't overwrite each other
        string fileName = isCapabilities
            ? $"capabilities_{HashUrl(GetBaseUrl(url))}.xml"
            : HashUrl(url) + ".png";
        string filePath = Path.Combine(_cacheRoot, fileName);
        // Check Offline Cache
        if (File.Exists(filePath))
            var bytes = await File.ReadAllBytesAsync(filePath, cancellationToken);
            var response = new HttpResponseMessage(HttpStatusCode.OK)
                Content = new ByteArrayContent(bytes)
            if (isCapabilities)
                // Explicitly set the content type to XML
                response.Content.Headers.ContentType = new System.Net.Http.Headers.MediaTypeHeaderValue("text/xml");
                // IMPORTANT: Ensure the "Content-Encoding" header is NOT set to "gzip"
                // because the file on disk is already decompressed now.
                response.Content.Headers.ContentEncoding.Clear();
            else
                response.Content.Headers.ContentType = new System.Net.Http.Headers.MediaTypeHeaderValue("image/png");
            return response;
        var webResponse = await base.SendAsync(request, cancellationToken);
        if (webResponse.IsSuccessStatusCode)
            var data = await webResponse.Content.ReadAsByteArrayAsync(cancellationToken);
            await File.WriteAllBytesAsync(filePath, data, cancellationToken);
        return webResponse;
    private bool IsCapabilitiesRequest(string url)
        // Check for KVP (Key-Value Pair) style: ?request=GetCapabilities
        // Or RESTful style: /WMTSCapabilities.xml
        return url.Contains("GetCapabilities", StringComparison.OrdinalIgnoreCase) ||
               url.EndsWith("WMTSCapabilities.xml", StringComparison.OrdinalIgnoreCase);
    private string GetBaseUrl(string url)
        return url.Split('?')[0];
    private string HashUrl(string url)
        // Simple MD5 or SHA hash to turn a long URL into a safe filename
        using var md5 = System.Security.Cryptography.MD5.Create();
        byte[] inputBytes = System.Text.Encoding.ASCII.GetBytes(url);
        byte[] hashBytes = md5.ComputeHash(inputBytes);
        return Convert.ToHexString(hashBytes);
Leo
Thanks Leo,
I do not find 14.5.0-beta080 from the nuget.
The latest version to me is 14.5.0-beta075 only.
hi @Jimmy_Pun,
Could you try it again? I’m 100% sure it’s available.
https://www.nuget.org/packages/ThinkGeo.Core/14.5.0-beta080
Leo
Hi Leo,
I found the version now. Thank you.
However, the ArcGisServerRestVectorAsyncLayer renderering speed is far slower than ArcGisServerRestRasterAsyncLayer (and also compare with the Esri one). And it somehow blocks my base map get loaded.
Is there any way to improve it?
Attached the latest sample project…MauiApp1.zip (765.7 KB)
Hi Jimmy,
The issue was recreated and fixed, please get this version and have another try.
MauiApp1_modified_20260211.zip (206.1 KB)
The old version will always download the data with the highest precision, this new version automatically download the right data based on the current scale. For your specific case, before it downloaded over 15M of json and now it’s around 400k.
Also we made some changes such as put the background map to a different overlay, and set up the OutFields, etc.
Have a try and let us know.
