I tried installing the ThinkGeo.FileGeoDatabase Nuget Package. 14.4.0 Beta005
I get following warning:
There was a mismatch between the processor architecture of the project being built “MSIL” and the processor architecture of the reference “.nuget\packages\thinkgeo.dependency.filegeodatabase\14.0.0\lib\net462\Esri.FileGDBAPI.dll”, “AMD64”. This mismatch may cause runtime failures. Please consider changing the targeted processor architecture of your project through the Configuration Manager so as to align the processor architectures between your project and references, or take a dependency on references with a processor architecture that matches the targeted processor architecture of your project.
When trying to run the project, I get following FusionLog:
=== State information before binding ===
LOG: DisplayName = Esri.FileGDBAPI, Version=1.5.2.308, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86
(Fully-specified)
LOG: Appbase = file://bin/Debug/
LOG: Original PrivatePath = NULL
LOG: DynamicBase = NULL
LOG: CacheBase = NULL
LOG: AppName = Viewer.exe
Call of Assembly : ThinkGeo.FileGeoDatabase, Version=14.0.0.0, Culture=neutral, PublicKeyToken=0828af5241fb4207.
LOG: This binding starts in the default load context.
LOG: The application configuration file is used: \bin\Debug\Agk_Viewer.exe.Config
LOG: The host configuration file is used:
LOG: The computer configuration file from C:\Windows\Microsoft.NET\Framework\v4.0.30319\config\machine.config is used.
LOG: Reference according to the policy: Esri.FileGDBAPI, Version=1.5.2.308, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86
LOG: The search in the GAC was not successful.
LOG: Download from new URL file:file://bin/Debug/Esri.FileGDBAPI.DLL.
LOG: The assembly download has been performed. File setup is started: \bin\Debug\Esri.FileGDBAPI.dll.
LOG: The setup phase executed by the source begins.
LOG: The assembly name is: Esri.FileGDBAPI, Version=1.5.2.308, Culture=neutral, PublicKeyToken=8fc3cc631e44ad86.
ERR: Invalid assembly platform or ContentType in file (hr = 0x8007000b).
ERR: The setup phase executed by the source failed with hr = 0x8007000b.
ERR: The assembly setup could not be completed (hr = 0x8007000b).
Do you have any idea how to handle this?
Thank you!
