MapSuite doesn’t have the native support for Bezier but you can implement it by yourself. Generally you need:
First, draw the 2 lines on the map, please check HowDoI Sample->Editing Feature Layers->Track And Edit Shapes to see how to implement it.
Second, draw the Bezier line on the map. You can generate the Bezier line, get every point of it and create a lineShape, and draw that lineshape out by adding it to an InMemoryFeatureLayer.
Third, whenever changing the posiition of the 2 lines, regenerate the Bezier line and redraw it on the map.
For the third one, I'll try tomorrow but I don't know yet how to know which point has moved. I have 2 fixed point in my curve and the curve is calculate with the 2 other points. Maybe with mouseup/down and mousemove...
You don’t have to handle MouseUp/MouseDown/MouseMove events yourself, instead you can simply use EditOverlay’s VertexMoved event, which is raised after the control point is moved. The information of the vertex is also passed as MovedVertex property within the event argument.
