I have ran a fiddler trace on my current application and I found that a lot of time when “GET /tile_GeoResource.axd?..” the get does not return an IMAGE/PNG but text/html,charset=us-ascii… of course I do not understand why and moreover this could lead to some issues as well. the most disturbing is that the http code return when this is appening is 401 unautorized…
could look a the screen cast?
thanks in advance.
jm
screencast.com/t/oWwftlEz
More questions or bugs
Last but not least I ran the very same application with the daily build version 151 and I do not have the issue with this version. I think that I am having some issue with my application because of this behavior with the current 157 build.
jm.
Hi Jm,
I download the fiddler(it seems
a good web debugger tool) and monitor our sample, but I didn’t see the behavior
like yours. Here is my test video screencast.com/t/P2jOwhmytVsM
I also attached the test sample
which is very simple, would you please do some modifications if you have any
time?
For the second question, If what
I am guessing is correct, using 157 version is to fix the CAD issue but there
is a projection issue in your project, and using 151 is because there is no the
projection issue in your projection. Sorry about the projection issue, we try
to fix it but we still can’t recreate it and I guess there might be some
setting on the projection in your project. We hope you can create a
sample( or partial codes is fine) for us when you are free.
I don’t think there are any
issues using the 151 dlls and the unmanaged dlls 157 as they should be isolate. If any questions on them, please feel free to let us know.
001_DisplayASimpleMapForMvc.zip (164 KB)
