MouseClick vs MouseUp
 Hi
I am allowing the user to select assets when he clicks on the map. I'm using the MapClick event to do this.
My user has reported that if the mouse moves even a small distance between mouse down and mouse up the click is not registered.
My app runs on a touch sensitive tablet and this is a possibility with finger selection.
I thought that I could move my code from mapclick to mouseup to fix the problem but the mouseup event does not have the MapClickWinformsMapEventArgs property I need to find the click location.
Is there any way I can determine the current mouse location and convert it to a WorlLocation in MouseUp?
Cheers
Steve
 Here is how to convert a screen point to a WordLocation
void gisMap_MouseUp(object sender, MouseEventArgs e)
PointShape mapPoint = ExtentHelper.ToWorldCoordinate(gisMap.CurrentExtent,
new ScreenPointF(e.X, e.Y),
gisMap.ClientSize.Width, gisMap.ClientSize.Height);
Steve,
 I’m glad that you have found the solution for your scenario. Have a good day.
 Ivan
