Moving Feature to Edit, comes back without columns?
Hello, It's possible that I'm just doing this in a strange way and my thinking is messed up. Please let me know if that's the case.
I allow a user to create a polygon using track shapes. When they are through with the track shape, I gather some information from the user about the polygon they've defined and then I add the feature with some new columns (based on the input from the user) to a different layer and I clear the EditOverlay.EditLayer of all features. If the user then says that they want to edit the polygon, I move the feature back to the EditOverlay.EditLayer. (Do I need to do this? Is there a better way?)
(As an aside, when I do this, I refresh the map using Map.Refresh() but this doesn't refresh the Edit Overlay, I have to do that separately, is that intentional?)
After the user has modified the zone and specify that they are done, I want to move the zone back to my other layer and remove it from the edit layer, while keeping the original columns. What happens is that I get the feature from the edit layer and it doesn't have any columns of column values. I tested to ensure that the column values are there right as I'm adding it to the edit layer, but the feature I get back no longer has them.
Is there a different way I should be going about this problem? I can think of a work-around, but it doesn't seem as clean.
Kimberly
Kimberly,
You don’t need to clear all the features in EditOverlay before user starts to edit the shape. After you set property:
winformsMap1.EditOverlay.TrackMode = TrackMode.Edit;
user can select shape by clicking on the map to edit.
There is a known issue when call Map.Refresh() it doesn't refresh the EditOverlay. To avoid this issue you can call
winformsMap1.RefreshEditOverlay();
refresh it manually.
We also noticed the column data is missing after user edits the shape; we will fix these bugs in the next version. Sorry for the inconvenience for now.
ThinkGeo Support
