MS SQL 2008 FeatureSource with Heat Map out of memory exception
I'm new to using the MsSql2008FeatureSource and the HeatLayer technologies in the 5.0 release. The first issue I ran into, and "corrected" was that the primary key for my data is a Guid and that doesn't work, so I exported a set of data into a different table with an Int primary key for testing. I am using SQL Server 2008 Express but can use Enterprise if there is an issue with Express. My table consists of MapPointID (int), LocationDescription(varchar(255)), LocationLatitude and LocationLongitude(decimal(14,12), and MapPoint, a Geography data type in SRID 4269. I am using the CSharp VS2010 sample, "New Features > Load A Heat Layer" as reference code with my simple additions. When I changed to using the SQL feature source using the remaining code as an example everything worked fine. I then took a larger extract of data. I now have 593k rows and it gives an "out of memory" exception pretty quickly. I have attempted using the WhereClause property - even setting it to "WHERE MapPointID < 10" but it still fails. I did notice that when inspecting the SqlStatement in the ExecutingSqlStatementMsSql2008FeatureSourceEventArgs that it forced capitalization of the MapPointID - but I am not sure that really matters. I inspected those SqlStatements repeatedly and it seems like it keeps checking for the data type of the column. I think it would be much easier and more efficient if the SpatialDataType value was not read only so I could simply set it and reduce the large number of redundant large queries to figure out what it is.
Do you have any insights as to what I can do to help this? Most of the time I will be limiting results displayed on a county level, however there will be times it needs to be state level. Am I supposed to "convert" my SQL 2008 data into another type to be able to return larger datasets? I will realistically have 300k+ rows that will need to be used in a heat map frequently.
Please help ASAP. Thanks,
Just as an update, I started with a separate table, using all CAPS for the column names, and have had more success. Naturally my PC is not as fast as our 16 core web servers, but plotting 90k records takes 28 seconds on a statewide level (Indiana). I have a spatial index on the table. Any performance improvement ideas? Obviously I can use a server cache but this data changes frequently so that may not be my best option.
David,
 For your question, could you sent us a simple sample? That will be helpful for us to locate the problem, it’s not easy to create a database just like your real environment.
