MsSql2008FeatureLayer question
We have data on the MS SQL server and we are using MsSql2008FeatureLayer. Every object in table has property for displaying in predefined zoom (e.g. town Berlin has set property value on 5 and so it will be displaied from zoom 5).
How can I set the condition for ZoomLevelSet in MsSql2008FeatureLayer? Do you have an example?
Ondrej
Ondrej,
I think there is no need to create your own ZoomLevelSet, Following code is some way I can think about, if you have any better idea, just let me know.
 private void SetUpLayer(FeatureLayer targetLayer, int zoom, AreaStyle araStyle, LineStyle lineStyle, PointStyle pointStyle)
            switch (zoom)
                case 1:
                    if (araStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = araStyle; }
                    if (lineStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle = lineStyle; }
                    if (pointStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = pointStyle; }
                    break;
                case 2:
                    if (araStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel02.DefaultAreaStyle = araStyle; }
                    if (lineStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel02.DefaultLineStyle = lineStyle; }
                    if (pointStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel02.DefaultPointStyle = pointStyle; }
                    break;
                case 3:
                    if (araStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel03.DefaultAreaStyle = araStyle; }
                    if (lineStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel03.DefaultLineStyle = lineStyle; }
                    if (pointStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel03.DefaultPointStyle = pointStyle; }
                    break;
                case 4:
                    if (araStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel04.DefaultAreaStyle = araStyle; }
                    if (lineStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel04.DefaultLineStyle = lineStyle; }
                    if (pointStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel04.DefaultPointStyle = pointStyle; }
                    break;
                case 5:
                    if (araStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel05.DefaultAreaStyle = araStyle; }
                    if (lineStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel05.DefaultLineStyle = lineStyle; }
                    if (pointStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel05.DefaultPointStyle = pointStyle; }
                    break;
                case 6:
                    if (araStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel06.DefaultAreaStyle = araStyle; }
                    if (lineStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel06.DefaultLineStyle = lineStyle; }
                    if (pointStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel06.DefaultPointStyle = pointStyle; }
                    break;
                case 7:
                    if (araStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel07.DefaultAreaStyle = araStyle; }
                    if (lineStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel07.DefaultLineStyle = lineStyle; }
                    if (pointStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel07.DefaultPointStyle = pointStyle; }
                    break;
                case 8:
                    if (araStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel08.DefaultAreaStyle = araStyle; }
                    if (lineStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel08.DefaultLineStyle = lineStyle; }
                    if (pointStyle != null) { targetLayer.ZoomLevelSet.ZoomLevel08.DefaultPointStyle = pointStyle; }
                    break;
                default:
                    break;
No. I need to set condition to MsSql2008FeatureLayer. I have table on SQL 2008, there are geometry objects with property Category. Category is from 1 to 5. I need add to LayerOverlay 5 layers of type MsSql2008FeatureLayer, but with condition (Category = 1, Category = 2, Category = 3, Category = 4, Category = 5).
After I set a ZoomLevelSet. But the getting of datas by value is the problem.
Ondrej
Ondrej,
 Do you mean you have a SqlServer table which contains geometry column and category column; what you want to do is that, for example.
 If the category is 1, display all the data whose category is 1 from zoom level 1 to 20;
 If the category is 2, display all the data whose category is 2 from zoom level 2 to 20;
 Please point out if there is any misunderstanding so that I can provide you a sample correctly.
 Howard
Yes Howard, your example is right. I want display 5 MsSqlLayers via column Category value.
Ondrej,
Hope the following code makes sense. Any questions please let me know.
MsSql2008FeatureLayer layer1 = new MsSql2008FeatureLayer("[ConectionString]", "[TableName]", "IdColumn");
layer1.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(GetValueStyle("1", AreaStyles.Country1));
layer1.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
MsSql2008FeatureLayer layer2 = new MsSql2008FeatureLayer("[ConectionString]", "[TableName]", "IdColumn");
layer2.ZoomLevelSet.ZoomLevel02.CustomStyles.Add(GetValueStyle("2", AreaStyles.Country2));
layer2.ZoomLevelSet.ZoomLevel02.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
MsSql2008FeatureLayer layer3 = new MsSql2008FeatureLayer("[ConectionString]", "[TableName]", "IdColumn");
layer3.ZoomLevelSet.ZoomLevel03.CustomStyles.Add(GetValueStyle("3", AreaStyles.County1));
layer3.ZoomLevelSet.ZoomLevel03.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
MsSql2008FeatureLayer layer4 = new MsSql2008FeatureLayer("[ConectionString]", "[TableName]", "IdColumn");
layer4.ZoomLevelSet.ZoomLevel04.CustomStyles.Add(GetValueStyle("4", AreaStyles.County2));
layer4.ZoomLevelSet.ZoomLevel04.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
MsSql2008FeatureLayer layer5 = new MsSql2008FeatureLayer("[ConectionString]", "[TableName]", "IdColumn");
layer5.ZoomLevelSet.ZoomLevel05.CustomStyles.Add(GetValueStyle("5", AreaStyles.Crop1));
layer5.ZoomLevelSet.ZoomLevel05.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
LayerOverlay overlay = new LayerOverlay();
overlay.Layers.Add(layer1);
overlay.Layers.Add(layer2);
overlay.Layers.Add(layer3);
overlay.Layers.Add(layer4);
overlay.Layers.Add(layer5);
Map1.CustomOverlays.Add(overlay);
private ValueStyle GetValueStyle(string columnValue, Style style)
    ValueStyle style = new ValueStyle();
    style.ColumnName = "Category";
    style.ValueItems.Add(new ValueItem(columnValue, style));
    return style;
Howard
Yes, Howard, thank you very much.
Ondrej
Ondrej,
 You are welcome. Please feel free to let me know if you have any queries.
 Howard
