Multi Line Label TextStyle method
Can an InMemeoryFeatureLayer have more than one TestStyle? Is my method below possible? I tried adding OFFLabels1, yet only OFFLabels will display. What might I pay attention to for this to work? Thanks. I am going to hit submit even though the preview window is space delimiting my code. I hope it displays as it shows in the Format Code Block window preview and as I see it here in Create New Topic.
Private Sub Offices_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Offices.Click
  If Offices.Checked = False Then
    If command IsNot Nothing Then command = Nothing
    If dataReader IsNot Nothing Then dataReader = Nothing
    Try
      OFFconn.Open()
      Offices.Checked = True
      Dim OfficesTag As String = "SELECT * FROM Offices ORDER BY ID;"
      command = New OleDbCommand(OfficesTag, OFFconn)
      dataReader = command.ExecuteReader()
      Dim i As Integer
      If dataReader.FieldCount > 0 Then
        bolOFF = True
        If Map.Overlays.Contains("Offices") = False Then
          OFFLayer = New InMemoryFeatureLayer()
          OFFLayer1 = New InMemoryFeatureLayer()
          Dim OfficesValue As New ValueStyle()
          OfficesValue.ColumnName = "Name"
          Do While dataReader.Read()
            OfficesValue.ValueItems.Add(New ValueItem(dataReader("Name").ToString, New PointStyle((New GeoImage(Application.StartupPath + "\ATMOSIconSmall.ico")))))
          Loop
          ‘create Office Designation/Name label
          Dim OFFLabels As TextStyle
          OFFLabels = New TextStyle("Name", New GeoFont("Arial", 12), New GeoSolidBrush(GeoColor.StandardColors.Black))
          OFFLabels.XOffsetInPixel = 10
          ‘OFFLabels.YOffsetInPixel = 7
          OFFLabels.Mask = New AreaStyle(New GeoPen(GeoColor.StandardColors.AntiqueWhite, 1), _
                                         New GeoSolidBrush(GeoColor.StandardColors.WhiteSmoke))
          ‘create Office Address label
          Dim OFFLabels1 As TextStyle
          OFFLabels1 = New TextStyle("Address", New GeoFont("Arial", 12), New GeoSolidBrush(GeoColor.StandardColors.Black))
          OFFLabels1.XOffsetInPixel = 10
          OFFLabels1.YOffsetInPixel = 10
          OFFLabels1.Mask = New AreaStyle(New GeoPen(GeoColor.StandardColors.AntiqueWhite, 1), _
          ‘add label layers
          OFFLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(OFFLabels)
          OFFLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(OFFLabels1)
          ’              OFFLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(TextStyles.City2("[Name]" & " - " & "[Address]"))
          ’              OFFLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle.YOffsetInPixel = 50
          ’              OFFLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle.OverlappingRule = LabelOverlappingRule.AllowOverlapping
          OFFLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(OfficesValue)
          OFFLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
          OFFLayer.Open()
          OFFOverlay.Layers.Add(OFFLayer)
          Map.Overlays.Add("Offices", OFFOverlay)
          For i = 0 To dataReader.FieldCount - 1
            OFFLayer.Columns.Add(New FeatureSourceColumn(dataReader.GetName(i)))
            OFFstr.Add(dataReader.GetName(i).ToString)
          Next i
        End If
        OFFLayer.EditTools.BeginTransaction()
        ’ We now loop though all of the results and build up our features that we need to return.
          Dim OfficesFeature As New Feature(CDbl(dataReader("Longitude")), CDbl(dataReader("Latitude")))
            OfficesFeature.ColumnValues(dataReader.GetName(i)) = dataReader(dataReader.GetName(i)).ToString
          Next i
          OFFLayer.EditTools.Add(OfficesFeature)
        Loop
        OFFLayer.EditTools.CommitTransaction()
      Else
        MessageBox.Show("Offices Error!" + Environment.NewLine + "No Records Found!", "Data Error!", MessageBoxButtons.OK)
      End If
    Catch ex As Exception
      MessageBox.Show("Offices Error!" + Environment.NewLine + ex.Message, "Connection Error!", MessageBoxButtons.OK)
    Finally
      ’ Cleanup any of the objects that need to be closed or disposed.
      If command IsNot Nothing Then command.Dispose()
      If dataReader IsNot Nothing Then dataReader.Dispose()
    End Try
  Else
    If Map.Overlays.Contains("Offices") = True Then Map.Overlays.Remove(Map.Overlays("Offices"))
    OFFconn.Close()
    bolOFF = False
  End If
  Map.Refresh()
  If Not bolLoad Then SaveINI()
End Sub
OFFLabels1.YOffsetInPixel = -20 is all I had to modfy to make this work. I hope someone might get something out of this.
These settings cause OFFLabels1 to disappear.
OFFLabels.YOffsetInPixel = 5
OFFLabels1.YOffsetInPixel = -12
Anything greater than -13 will not display OFFLabels1 properly. It is woking though.
Hi Craig,
Thanks for your post, "ClassBreakStyle" should be able to fit it, attached is the sample code,would you please check it? Following is a result image of our test:
Hope it helps
Summer
Post11333sample.txt (1.19 KB)
