Multiple colored markes
  I would like to show multiple markers, but of different colors.  I seem to be having difficulty doing so with the following code.  I have read that it is not recommended to use multiple marker layers.  Please advise as to how I may accomplish this.  Code follows:
            if (!Page.IsPostBack)
                Map1.MapBackground.BackgroundBrush = new GeoSolidBrush(GeoColor.FromHtml("#B3C6D4"));
                Map1.CurrentExtent = new RectangleShape(-88.1422, 42.4009, -87.5169, 41.4529);
                //Map1.MapTools.PanZoom.Enabled = true;
                Map1.MapTools.PanZoomBar.Enabled = true;
                ShapeFileFeatureLayer defaultLayer = new ShapeFileFeatureLayer(Server.MapPath("~/Map/ILlkA.shp"));
                defaultLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(LineStyles.LocalRoad1);
                defaultLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
                defaultLayer.Name = ("defaultLayer");
                ShapeFileFeatureLayer railLayer = new ShapeFileFeatureLayer(Server.MapPath("~/Map/ILlkB.shp"));
                railLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(LineStyles.Railway1);
                railLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
                ShapeFileFeatureLayer defaultStreetsLabelLayer = new ShapeFileFeatureLayer(Server.MapPath("~/Map/ILlkA.shp"));
                defaultStreetsLabelLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.LocalRoad1("FENAME");
                defaultStreetsLabelLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
                defaultStreetsLabelLayer.DrawingMarginPercentage = 100;
                defaultStreetsLabelLayer.Name = ("defaultStreetsLabelLayer");
                Map1.StaticOverlay.Layers.Add(railLayer);
                Map1.StaticOverlay.Layers.Add(defaultLayer);
                Map1.StaticOverlay.TileType = TileType.MultipleTile;
                Map1.DynamicOverlay.Layers.Add(defaultStreetsLabelLayer);
                // The following two lines of code enable the client and server caching.
                // If you enable these features it will greatly increase the scalability of your
                // mapping application however there some side effects that may be counter intuitive.
                // Please read the white paper on web caching or the documentation regarding these methods.
                Map1.StaticOverlay.ClientCache.CacheId = "defaultOverlay";
                Map1.StaticOverlay.ServerCache.CacheDirectory = MapPath("~/ImageCache/" + Request.Path);
                InMemoryFeatureLayer shapeLayer = new InMemoryFeatureLayer();
                shapeLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle =
                    PointStyles.CreateSimplePointStyle(PointSymbolType.Circle, GeoColor.StandardColors.Blue, 5);
                shapeLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
                Map1.DynamicOverlay.Layers.Add("pointShapeLayer", shapeLayer);
                CreatePoints(shapeLayer, "-87.8225020", "42.3754010");
                CreatePoints(shapeLayer, "-88.08842", "42.19746");
                CreatePoints(shapeLayer, "-88.063", "42.21907");
                CreateARedMarker("1", -87.8225020, 42.3754010);
                CreateAGreenMarker("2", -88.08842, 42.19746);
                CreateAGreenMarker("3", -88.063, 42.21907);
                shapeLayer.Open();
                Map1.CurrentExtent = shapeLayer.GetBoundingBox();
                shapeLayer.Close();
        private void CreatePoints(InMemoryFeatureLayer layer, string lon, string lat)
            Feature pointFeature = new Feature(new PointShape(
                double.Parse(lon, CultureInfo.InvariantCulture), double.Parse(lat, CultureInfo.InvariantCulture)));
            layer.InternalFeatures.Add(pointFeature.Id, pointFeature);
        private void CreateAGreenMarker(string key, double lon, double lat)
            StringBuilder contentHtml = new StringBuilder();
            contentHtml.Append("")
                .Append("This is a green sample hover popup")
                .Append("");
            Map1.MarkerOverlay.Features.Add(key, new Feature(lon, lat));
            Map1.MarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage = new WebImage("/MapTest/theme/default/img/marker_green.gif", 21, 25);
            Map1.MarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.ContentHtml = contentHtml.ToString();
            Map1.MarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.AutoSize = true;
            Map1.MarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.BorderWidth = 1;
            Map1.MarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.IsVisible = false;
            Map1.MarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.AutoPan = true;
            Map1.MarkerOverlay.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
        private void CreateARedMarker(string key, double lon, double lat)
                .Append("This is a red sample hover popup")
                .Append("");
            Map1.MarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage = new WebImage("/MapTest/theme/default/img/marker.gif", 21, 25);
Steven,
ValueMarkerStyle is what you need. Please see the attached code and screenshot of it.
Howard
982-DisplayASimpleMap.aspx.cs (2.6 KB)
