I tried changing width from 256256 to 20482047 but still see same number of banners on map.
Even tried 128128 but map is looking distorted and 40964096 is very slow.
When I changed to TileType to Single its application is hanging.
I have a valid Google client Id and Private key.
Issue can be reproduced with the below sample.Please go through below code sample and suggest me the workaround.
Thanks for your sample, please remove the client id and private key from it, or remove the download link.
Today our developer tried your sample but failed to render map after set the default tile size and set multiply tile mode.
We had removed the cache also, it still don’t shows anything.
So I think maybe we missed some point about your sample, could you please let us know your detail dll version and if we missed any step please let us know.
a. I means you should want to remove your download link, because it contains your client id and private key in your code. Here is a public forum and it will be visited by search engines also. So public your id and key here is unsafe. If you want to sent that to us for test, you can sent that by email or via our ticket system.
b. Even you set the tile size to 512 * 512, you cannot remove all the tile logo, when your map is bigger than the size. You can go on increase the tile size until the limitation from Google: Overview | Maps Static API | Google for Developers
Just like item 3 in my last reply, we hadn’t reproduced the issue in our machine use your code and the target version.
Have you tried the sample in any other machine without the same network and still can reproduce this problem? Or do you think you can upgrade the dll version to our latest version, I guess that’s maybe related with environment or dll version.
Any further information about it please let us know.
