Multiple loading of data : OnInitializedAsync
I’m facing slow loading of my map data. After debugging I found that my code is entering OnInitialized method 3 times which restart the loading of my data 3 times.
Can you please help me with that?
 protected override System.Threading.Tasks.Task OnInitializedAsync()
     osmLayers = new GeoCollection<LayerBase>();
     editingLayers = new GeoCollection<LayerBase>();
     highlightedFeaturesLayers = new GeoCollection<LayerBase>();
     LoadLayers();
     return base.OnInitializedAsync();
I couldn’t recreate the issue, OnInitializedAsync is only hit once on my side. Can you comment out the code in OnInitializedAsync and see if it helps?
protected override Task OnInitializedAsync()
If it still has the issue, just keep simplifying the code in your project until it works to debug it.
