Hello, I need to use 2 or more maps in the same webform, but the map control fails when postback, I mean, when the webform loads it shows the 2 maps but when I click in any button the map controls are shown in gray color.
Thanks for your help.
Multiple maps in webform
Hi Julieta,
If possible, please don’t put two maps on same page. Have you tried some other solution like iframe?
Hello Don, I´ve not tried with Iframe but it sounds like a good solution. Before I try the Iframe I´d like to know if I can do something like this:
I mean, I will add 3 iframe calling the same Mapform.aspx, is this possible? The 3 map controls contained in each Iframe operate separately or if I add a feature will be contained in all the map controls? I need the maps operate separately.
Thanks in advance.
Hi Julieta,
With your code I did a quickly test, it looks 3 maps works well in same page, but I cannot make sure all map feature can works well follow this way, if you met any problem please let us know.
