Hello
i would like to use a multipoint shape in edition mode (in the edit overlay) i have several questions :
- it is possible to move all the points at the same time, but this feature can be done by selecting another node which has exactly the same appearance than my actual points, is is possible to change the css of the point that enables me to move all the other points ?
- is it possible to delete a single point ?
- is it possible to create a point and add it to my multipoint
- apparently if i select a single point (in edit mode) of a multipoint and click on the map aside the point, the multipoint disappears, is it normal?
i dont know if it is possible but i would to do everything in javascript.
thanks for your help
