Greetings all,
Some of you may have noticed that the Video Walkthrough buttons in our Map Suite MVC Edition "How Do I?" sample apps are no longer working. This occurred in both our online MVC Edition sample apps, and the samples that are installed on your development machine when you install Map Suite MVC Edition.
This problem has already been resolved on our online sample apps. To correct this problem within your local copy of the MVC Edition "How Do I?" samples, please download the attached SampleList.xml file and replace the one on your development machine. If you have installed Map Suite MVC Edition to the default location, you will need to overwrite the XML file in each of the following folders:
- C:\Program Files (x86)\ThinkGeo\Map Suite Mvc Full Edition 7.0\HowDoISamples\CSharp HowDoISamples Razor\SampleList.xml
- C:\Program Files (x86)\ThinkGeo\Map Suite Mvc Full Edition 7.0\HowDoISamples\VB HowDoISamples Razor\SampleList.xml
Feel free to post a reply below if you have any questions.
Thanks for using Map Suite,
The ThinkGeo Team
SampleList.xml (38.1 KB)
