Need help to color point featureLayer
Hi
When adding points to layer in runtime, i can't get color by value to work. If I set the default style the map shows the points, but i would like to give each point af color by value:
Anybody any idea whats wrong....
(well clipboard is not working well on this forum :() long live Notepad
        private void Form1_Load(object sender, EventArgs e)
            mapControl.MapUnit = GeographyUnit.DecimalDegree;
            ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"C:\Program Files\ThinkGeo\Map Suite Desktop Evaluation Edition 3.0 (BETA)\Samples\SampleData\Data\Countries02.shp");
            InMemoryFeatureLayer pointLayer = new InMemoryFeatureLayer();
            //pointLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Red), 5);
            pointLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
            LayerOverlay pointOverlay = new LayerOverlay();
            worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.County2;
            ValueStyle valueStyle = new ValueStyle();
            valueStyle.ColumnName = "WINDSPEED";
            valueStyle.IsActive = true;
            valueStyle.ValueItems.Add(new ValueItem("0", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Blue), 2)));
            valueStyle.ValueItems.Add(new ValueItem("1", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Blue), 2)));
            valueStyle.ValueItems.Add(new ValueItem("2", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Blue), 2)));
            valueStyle.ValueItems.Add(new ValueItem("3", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Blue), 2)));
            valueStyle.ValueItems.Add(new ValueItem("4", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Blue), 2)));
            valueStyle.ValueItems.Add(new ValueItem("5", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Blue), 2)));
            valueStyle.ValueItems.Add(new ValueItem("6", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Blue), 2)));
            valueStyle.ValueItems.Add(new ValueItem("7", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Blue), 2)));
            valueStyle.ValueItems.Add(new ValueItem("9", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Blue), 2)));
            pointLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(valueStyle);
            pointOverlay.Layers.Add("PointLayer", pointLayer);
            layerOverlay.Layers.Add(worldLayer);
            mapControl.Overlays.Add(layerOverlay);
            mapControl.Overlays.Add("PointOverlay", pointOverlay);
            mapControl.CurrentExtent = new RectangleShape(0, 78, 30, 26);
            mapControl.Refresh();
        private void btnInsertPoints_Click(object sender, EventArgs e)
            double longStep = (9.3854 - 8.4) / 10.0;
            double latStep = (56.3780 - 55.5595) / 10.0;
            mapControl.Overlays["PointOverlay"].Lock.EnterWriteLock();
            try
                InMemoryFeatureLayer pointLayer = (InMemoryFeatureLayer)mapControl.FindFeatureLayer("PointLayer");
                double latidude = 55.5595;
                for (int i = 0; i < 10; i++)
                    double longitude = 9.3695;
                    for (int y = 0; y < 10; y++)
                        Feature feature = new Feature(longitude, latidude, "" + i + ":" + y);
                        feature.ColumnValues.Add("WINDSPEED", i.ToString());
                        pointLayer.InternalFeatures.Add("" + i + ":" + y, feature);
                        longitude += longStep;
                    latidude += latStep;
            finally
                mapControl.Overlays["PointOverlay"].Lock.ExitWriteLock();
            btnInsertPoints.Enabled = false;
Lars,
Thanks for your post and code!
You missed one thing in your application code; you have to add the feature source column when you created the InMemoryFeaturelayer.
Try the following code:
private void DisplayMap_Load(object sender, EventArgs e)
            ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"C:\Program Files\ThinkGeo\Map Suite Desktop Full Edition 3.0 (BETA)\Samples\SampleData\Data\Countries02.shp");
            FeatureSourceColumn column = new FeatureSourceColumn("WINDSPEED", "string", 10);
            Collection<FeatureSourceColumn> columns = new Collection<FeatureSourceColumn>();
            columns.Add(column);
            InMemoryFeatureLayer pointLayer = new InMemoryFeatureLayer(columns,new Feature[]{});
            valueStyle.ValueItems.Add(new ValueItem("0", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Blue), 1)));
            valueStyle.ValueItems.Add(new ValueItem("2", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Blue), 3)));
            valueStyle.ValueItems.Add(new ValueItem("3", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Blue), 4)));
            valueStyle.ValueItems.Add(new ValueItem("4", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Red), 1)));
            valueStyle.ValueItems.Add(new ValueItem("5", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Red), 2)));
            valueStyle.ValueItems.Add(new ValueItem("6", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Red), 3)));
            valueStyle.ValueItems.Add(new ValueItem("7", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Red), 4)));
            valueStyle.ValueItems.Add(new ValueItem("9", new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Red), 5)));
            winformsMap1.Overlays.Add(layerOverlay);
            winformsMap1.Overlays.Add("PointOverlay", pointOverlay);
            winformsMap1.CurrentExtent = new RectangleShape(0, 78, 30, 26);
            winformsMap1.Refresh();
        private void button1_Click(object sender, EventArgs e)
            winformsMap1.Overlays["PointOverlay"].Lock.EnterWriteLock();
            try
                InMemoryFeatureLayer pointLayer = (InMemoryFeatureLayer)winformsMap1.FindFeatureLayer("PointLayer");
                pointLayer.BuildIndex();
            finally
                winformsMap1.Overlays["PointOverlay"].Lock.ExitWriteLock();
Thanks for help, that make the difference
/Lars
 Lars,
 Thanks for letting me know your progress!
